Topic: how to get work importing manufacturers dxf
I tried the new dxf importer. Works fine with dxf created by myself.
But.
If I try to import Siemens or Phoenix files nothing happens.
..............Example...........
./dxf2elmt ~/Data/TMP/Untitled.dxf -v
<?xml version = "1.0" encoding = "UTF-8"?>
<definition height="10" width="10" hotspot_x="0" hotspot_y="0" version="0.80" link_type="simple" type="element">
    <uuid uuid="{51843470-7aa6-45a5-8e21-0333332679d1}" />
    <names>
        <name lang="en">/home/td/Data/TMP/Untitled</name>
    </names>
    <informations>Created using dxf2elmt!</informations>
    <description />
</definition>
How do I get it work?
TIA
Thomas
2 (edited by Calypso 2022-10-09 09:38:52)
Re: how to get work importing manufacturers dxf
try this DXF file
With best regards
Stebo
Sending issue to https://github.com/antonioaja/dxf2elmt/issues/1
Calypso wrote:
try this DXF file
With best regards
Stebo
What's the difference?
Does the export work? If so, it's probably because the drawing elements are shown as blocks in the original drawing that the DXF2elmt can't edit. I dissolved the blocks in the original drawing.
Best Regards
Stebo
Calypso wrote:
Best Regards
Stebo
Yes, it worked. And I could reproduce the dxf changes.
Thank you
Thomas
Creator of the conversion program here. dxf2elmt does not currently support the entities in that the .dxf file, as mentioned by another commenter. Support for this will hopefully be added soon.
-Antonio
