Topic: Wire label formulas
Hello all,
I am learning how to use qelectrotech to build panel diagrams/ladder diagrams. I have been manually labeling everything which is working fine but would like to eventually learn how to set up the auto labeling for wires, terminal points, elements and so on. I believe I may be getting confused by the structured text code some users are using.
So my first question is how do you get the simple label/text formulas to work and are the formulas different for: folio, elements, cable, wire, terminal blocks.
The one that I would benefit most from would be the wire label.
These formulas are the only ones that I seem to be able to get working:
%id
%f
%_sequ1 - only works sometimes
I have tried %l for the row and %c for the column but the formula only returns itself.
My second question is where do you run the code for the structured text/python. (do you need to edit files in the qelectro program folder?)
Thank you all for your help!
Re: Wire label formulas
see
https://qelectrotech.org/forum/viewtopi … 905#p15905
https://qelectrotech.org/forum/viewtopi … 906#p15906
3 (edited by lowVoltage 2022-06-12 22:59:20)
cmckinley wrote:
Hello all,
...I have tried %l for the row and %c for the column but the formula only returns itself.
If I may offer...
When a formula "only returns itself", this means that it is not a valid formula for the specific purpose.
This is to say that %l and %c are not applicable to conductor numbering.
(these formula are specifically applicable to element-numbering)
I believe it is correct to say that the formulas applicable to conductor-numbering are:
        No Scheme (%id)  (this is the folio position in the project, for example sheet 2)
        Number Format (%sequ1)
        Number Format - Folio (%sequF_1)
        Folio (%F)
        Plant (%M)
        Text
I believe this is correct in all details, and I invite correction by those with better understanding than I.
I hope this is helpful for you.
