1 (edited by jkaminski 2021-05-17 18:59:47)
Topic: Linux display issue with the Terminal Block Generator window [Solved]
I am using Ubuntu 18.04 with the i3 window manager. It might be my setup which causes the issue, but there might be some software configuration to have it fixed.
EDIT:
modifying the background variable in my ~/.Xresources file helped, file change:
!! *background:       #1b1918 !! dark background, now commented
*background:       #ededed !! gray background, now in use
The problem: The contents of the plugin window are not visible. Screenshot is attached.
The button "Create Terminal Block" becomes visible though every time I hover over it with a mouse.
Do you have some recommendations for potential fixes? Could it be PySimpleGUI which causes the issue?
Thank you for your time and consideration.
Regards,
Jakub
