Topic: Title block lines not printing
Hello all,
I have one issue when I am printing the documentation on the paper. I have created my own title block. When I export it to the PDF everything is OK, but when I print it on the paper I am missing some lines in the title block.
Have you faced the same problem?
Thank you.
With kind regards,
Marek
Re: Title block lines not printing
https://qelectrotech.org/forum/viewtopic.php?id=1552
Thanks, S.DEFFAUX.
It seems that issue is the resolution of drawings compare to printer possibilities.
I tried today to print drawing on A3 format and all lines are printed.
So have to think about changing the setting of folio dimensions.
Best regards,
Marek
After test of the latest release 0.8 dev I found out, that there is a new button - export to PDF - and this export generates a PDF which my printer is able to print - all lines are now on the printed page.
Thanks to the development team!
BR,
Marek
