Topic: Installing Ubuntu version 0.7
I downloaded your DEB packages from
Index of /qet/tags/20190717/Debian/stable/amd64/ ...
But i have a dependency error for  libqt5con...
looked at your reply about version 05,
where do I find the missing dependecy ?
Re: Installing Ubuntu version 0.7
What your Ubuntu version?
sudo apt-get install -f
https://qelectrotech.org/wiki_new/doc/install_ubuntu
Description:    Ubuntu 16.04.6 LTS
Release:    16.04
Codename:    xenial
You can't upgrade your Ubuntu LTS?
BTW, try AppImages.
https://qelectrotech.org/forum/viewtopic.php?id=1256
Only make it executable for running.
Or install snap package:
https://snapcraft.io/install/qelectrotech/ubuntu
https://snapcraft.io/qelectrotech
7 (edited by DerekvGbe 2020-04-14 17:29:32)
I followed these instructions
then I had version 0.5   but i could change the colour of a line
so i changed the pinning from
Package: qelectrotech*
Pin: version 0.60.*
Pin-Priority: 1001
to
Pin: version 0.70.*
Pin-Priority: 1001
then
apt-get update
apt-get install qelectrotech qelectrotech-data qelectrotech-examples qet-tb-generator
when I start this is about Qelectro
Qelectro tech v0.5
compilation gcc 5.3.1 2015207 built with Qt5.5.1 ..
now i cannot even change the colour of a line any more
and there is no dual colour
Why should i go to 18.04  LTS  which is shit
I cannot configure my network  and I cannot use my network  I had to reinstall form scratch  to 16.04 LTS  because of this canonical network shit
Qelectro tech v0.5
I removed
apt-get remove qelectrotech qelectrotech-data qelectrotech-examples qet-tb-generator
and installed the downloaded *.deb files
LIBQT5  is installed
but the package will not install ,  de dependency is in error
Try AppImage.
Tried every thing you've said ,
Install doesn't work   it keeps giving me 0.5  and says then that i have the latest version installed
after removing the  0.5 versions  despite  havign installed the libqt5  libraries
i cannot install the deb files i've downloaded from your site  because of a libqt5 dependency error
i will now auto remove
The following packages were automatically installed and are no longer required:
  blt libqt5clucene5 libqt5concurrent5 libqt5designer5 libqt5help5
  pyqt5-dev-tools python3-pyqt5 python3-sip python3-tk tk8.6-blt2.5
the apt preferences file
and the other references  ppa etc
pleasekeep me informed
Ubuntu Xenial is very old and not not supported now, Snap package or AppImages is the better solution for you.
Ubuntu Xenial is very old and not not supported now,.
My desktop has less then 1/3rd of time network connectivity  running  Ubuntu 18.04  I'm trying to back up and reinstall 16.04 LTS  because in the ubuntu community nobody wants to help  remove the netplan  blackbox network support  that cannot be configured and replace it with the ifupdown  version
When i installed this laptop from scratch with 18.04  it didn't have any network support at all, so i immediately reinstalle to 16.04
the reason this is happening is that canonical wants users to have black-box networking
the only thing you can select is  wired or wifi and set the ssid/password for your wifi connection
I cannot move forward  because of the failing network support
if I move to 18.04  i lose network connectivty  then   i lose my livelyhood and my business
imho the problen does not lie with  xenial
the dependency of the .deb files you offer is for another libqt5  then the one that gets downloaded form your PPA environment
what I don't understand is that installing from the APT repository gives me 0.5 instead of 0.7
what is required for a snap installation?  and for Appimages?
BTW, try AppImages.
Removed every thing  from the old installation attempts  then did SNAP  got 0.70  now
IT works
Thanks  for the help and your patience
With Snap you can also install 0.8-dev Snap packages, 0.8-dev is very better than old 0.7 stable version and add a lot a nice features..
