Topic: Type Field in Terminal Block Generator
Hi There-
What are the TYPES available for that field in the terminal block generator. With my trackpad on my Mac I cannot get a windows right click to work.
THanks!
Matt
QElectroTech → Terminal block generator → Type Field in Terminal Block Generator
Hi There-
THanks!
Matt
Hi Matt, see
https://www.cnet.com/how-to/five-ways-t … -trackpad/
Hi There-
I did exactly that and it works correctly except the plugin. Perhaps it's a python thing? I can of course type in the TYPE field and it works, I just don't know what all the options are. Is that documented anywhere?
Thanks!
Matt
Hi ,
I don't know, maybe Unalcade can help you, I saw he work on and devel Qet_tb_generator on macOS..
Hi Matt.
I don't use mac, so I can't verify your issue. However, you can write any of the 3 options directly in the TYPE field: STANDAR, GROUND or FUSE . The right click is to alternate between them quickly.
Generated in 0.034 seconds (15% PHP - 85% DB) with 9 queries
