What do you prefer ?
1 = first postion
2 = second position
3 = 3 position etc,
0 = always in last position
--- sources/projectview.cpp
+++ sources/projectview.cpp
@@ -363,7 +363,7 @@ void ProjectView::addNewDiagram() {
 void ProjectView::addNewDiagramFolioList() {
     if (m_project -> isReadOnly()) return;
     QSettings settings;
-    int i = (settings.value("projectview/foliolist_position").toInt()); //< Each new diagram is added  to the end of the project.
+    int i = (settings.value("projectview/foliolist_position").toInt() -1); //< Each new diagram is added  to the end of the project.
                //< We use @i to move the folio list at second position in the project
     foreach (Diagram *d, m_project -> addNewDiagramFolioList()) {
         DiagramView *new_diagram_view = new DiagramView(d);
@@ -885,7 +885,7 @@ void ProjectView::loadDiagrams()
     // If project have the folios list, move it at the beginning of the project
     if (m_project -> getFolioSheetsQuantity()) {
         for (int i = 0; i < m_project->getFolioSheetsQuantity(); i++)
-        m_tab -> tabBar() -> moveTab(diagram_views().size()-1, + (settings.value("projectview/foliolist_position").toInt()));
+        m_tab -> tabBar() -> moveTab(diagram_views().size()-1, + (settings.value("projectview/foliolist_position").toInt() -1));
         m_project->setModified(false);
--- sources/ui/configpage/generalconfigurationpage.cpp
+++ sources/ui/configpage/generalconfigurationpage.cpp
@@ -55,7 +55,7 @@ GeneralConfigurationPage::GeneralConfigurationPage(QWidget *parent) :
     ui->m_export_terminal->setChecked(settings.value("nomenclature-exportlist", true).toBool());
     ui->m_border_0->setChecked(settings.value("border-columns_0", false).toBool());
     ui->m_autosave_sb->setValue(settings.value("diagrameditor/autosave-interval", 0).toInt());
-    ui->m_foliolist_sb->setValue(settings.value("projectview/foliolist_position", 1).toInt());
+    ui->m_foliolist_sb->setValue(settings.value("projectview/foliolist_position", 2).toInt());
     QString fontInfos = settings.value("diagramitemfont").toString() + " " +
                         settings.value("diagramitemsize").toString() + " (" +
