Topic: [Question] Is it possible to use a project property in a text box?
As in the title, I'd like to add a text box in a page and fill it with a property field placeholder, so it gets replaced by the property's value like in the title block.
Is this possible?
Re: [Question] Is it possible to use a project property in a text box?
Not possible with the "normal" text fields (the button on the left of "insert image").
Clear, thank you. I switched to using the title block more, which I think is actually more appropriate.
You could draw a element and in your element in formula label field  add template variable :
https://download.qelectrotech.org/qet/forum_img/template_variable3.png
Thank you! That's clever!
