Topic: Update on edit
Hello..
I have question how to update drawing after editing component.
This is my situation:
A had to create one big PLC.
Now I see that some text/pins should be on different places. So I try to edit them.
In schematic I do right click on component and select "edit the element" and in popup window I select "general" tab and click on "edit element"
Now I edit element and save them.
But in schematics the element is not updated. I need to do that manualy and I lost all wires doing that. How to avoid that?
running ubuntu 14.04 and
[size=4]QElectroTech V 0.60-RC2+svn4992
Compilation: GCC 4.8.4 - built with Qt 5.2.1 - run with Qt 5.2.1
p, li { white-space: pre-wrap; }
Re: Update on edit
Hello Eslavko,
make a backup before, now drag and drop on your scheme the modified element saved again, a dialog appear which you propose to remplace, use two versions, etc.
Save and relauch your project.
Cross yours fingers. nomicons/smiley-green
Nuri wrote:
The software has no function to do this, but there is a workaround that might work:
Make a backup of your project before !!!
you go to the "Collections" panel
you open your project (at the top of the tree directory of the collections), then / imported items ... until you find your component.
Then double click on the part to edit it.
Make the changes you want to make.
Save, close component editor.
Save and close your project.
Reopen your project and see if the changes are visible.
Usually:
graphical changes are well supported. For example, change color or add or delete some graphic shapes.
Moving, deleting or adding static texts usually works very well
Moving, deleting or adding ports (the red terminals) usually does not work or does not work as expected
Moving, deleting or adding dynamic texts usually does not work or works as expected
Re: Update on edit
Similar issue: if I updated an imported element within a project, shouldn't it be updated in all instances?
For instance, I tried adding a dynamic text field to a connector pin, I'd like for that connector to show the text field in all instances. That would be EXTREMELY convenient I believe.
Re: Update on edit
@clabacchio
If you add the dynamic text from the diagram editor it won't work!
Because this is the purpose why "dynamic texts" have been implemented: to give you the possibility to add some text on a particular instance of an element. That's the reason why they had been named DYNAMIC texts.
If you want that your changes are made in all instances of the element, do this:
But I'm not sure it will work...
It works very good with STATIC texts.
Re: Update on edit
Indeed, that's what I've tried to do, editing the imported element, reloading the collections and close/reopen.
I've also tried two other ways:
1. Saving and loading the text fields configuration in the element's properties, one by one. Unfortunately, every time I add the text field to the element, it sets the default font size to 9, despite having saved it as (for instance) 7. Plus, I have to do it to every element one by one.
2. Editing the schematic file as text, directly copy-pasting the text field in the xml structure of every component. The two things I don't like of this approach are that the text is explicit and not linked to the component's attributes, so I have to copy-paste the label as well to each component; second, the uuid of the text field is copied as well, though I don't know how big a problem it is.
Re: Update on edit
It's obviously the most effective way at the current time to achieve what you want to do.
But it's risky! nomicons/unsure
Make a backup of your project before you tweak its xml content.
7
Re: Update on edit
 I agree it's risky, and not very convenient unless I rig up some script to do it for me...
But I tried again with the text field method (probably with a more recent dev version of QET) and now I'm getting consistent results, with the right text size and orientation. Now it's still a bit of a mechanic work, but much less demanding and tedious!
8
Re: Update on edit
In latest 0.7 dev, go to settings dynamic text field, choose font size 7, now open your element in element editor save as to your custom collection, add your new dynamic texts in element and save it.
Drag and drop your element modified on diagram, now a popup ask if you want to overwite symbol, etc choose overwrite, save as to new project name (backup), and re open your project, all instance of this element as changed by your modified element.
