Topic: List of folio
Hi!i'm new in forum.
I can ask: it's possible change or modify the "List of Folios"??i need erase some column.
thanks and regards
QElectroTech → EN : Help, suggestions, discussions, ... → List of folio
thanks and regards
Hi
No is hard coded
ok thanks.
if posible make a crossreference in the "textfield"??or only in label of elements?
Could you explain what you want to doing, and what your version?
My version is 5.10.1.
I need make my own list of folios because default list its too long. I need only the Tittle of folio and folio number.
In other version (0.4), this list of folios it was created in two columns, what occupies less space.
I think created textfield and write one by one the all folios in the scheme
Ouch, very terrible solution.
In your case I tried to export project to csv file, open this file in tablesheet like OOo or excel select Tittle of folio and folio number copy on new document like world and save to image, add image in your folio...
Like this old example :
Ok perfect. it's a solution.
but now I do not know how to export to csv. in the options I have png, jpg, bmp, svg and dxf. I use windows
thx
In menu project -> export parts list.
perfect thanks!!!
now, and sorry for my inconvenience; in text field i can use crossreference in textfield?
I did tests and it only allows me to use the references (for example %author) in the elements (circuit breaker, contact, etc)
thx
No ! independent text added on diagram can't add %variables.
in this repo you could find some videos howto not published on youtube :
I'll let you search
https://download.qelectrotech.org/qet/forum_img/
They are some references you can use :
For titlebocks
For elements
For reports
Generated in 0.033 seconds (15% PHP - 85% DB) with 10 queries
