Topic: Find elements (ctr-F)
Hi!
How can I single out one or more elements in a schema by the name of a label, for example?
I have two wires - 45.1 and 45.2.
I want to find '45' for them on the diagram. Is this possible?
QElectroTech → EN : Help, suggestions, discussions, ... → Find elements (ctr-F)
Hi!
It seems that there is no explicit way to find an element in the drawing. Maybe there is not explicit? Somewhere in the file, information can be stored, you can see it ...
Hello, no for the moment there isn't a function "find" in QElectroTech, but it's already in the todo-list (find, replace etc...).
Hello! Although screaming, even if they were stuck, without searching for a wire I can not use the program for more complex products. And so you want! How are things with this issue?
at this time find utils is impemented for report link, master and slave elements for quick searching by conductors with report free or elements master or slave for connect them.
Is very fast to search report free link by conductor name, function, protocol, folio, etc.
Same for master/slave element is so quickly to find master by example a coil to link with new slave contact you just added on diagram you could search and filter by coil label, comment, or by folio name.
I understand :
damn but where is this fucking conductor /element in my project of 100 folios, shit.
That's why I use a lot of reports conductors and master/slave elements in my projects.
https://download.qelectrotech.org/qet/s … a_bois.pdf
https://download.qelectrotech.org/qet/s … 19.qet.pdf
Search functions are already coded, but deliberatery limited in search for linking elements, maybe it would not be too difficult to create the same widget to search for a conductor number or an element label in the project and click on item for view.
Generated in 0.019 seconds (25% PHP - 75% DB) with 10 queries
