Topic: Polygon Error
Using 0.7dev-5297 ready-to-use under win7 I found that in the element editor QET hangs when finalizing a polygon
Regards,
Dik
QElectroTech → EN : Help, suggestions, discussions, ... → Polygon Error
Regards,
Dik
Hi Dik,
not tried under win7, but here Debian Sid it 's very fluid and quickly no hangs.
What ReadyToUse version you use, Qt 5.7.1 for Xp, Vista, or that for win 7 win 10 ?
Double click (left) for finish polygon primitive.
Hi scorpio810,
I used the ReadyToUse build for Win7/10
I was not aware of the left-doubleclick to end the Polygon command so I tried several times with Esc and/or rightclick. This caused QET to lock up.(repeatetly) When I use left-doubleclick as you suggested it works as expected.
BTW QET still locks up when using Esc during Polygon command in latest build 5322
Thank you
Dik
Generated in 0.037 seconds (21% PHP - 79% DB) with 10 queries
