Topic: Windows XP problem
Good evening, i have trouble running the version 0.51 development on xp with SP3, i have tried the portable and the install version, running one of it the first time i received a message indicating me that the dwmapi.dll wasn't found, so, "solved it", another message indicating unable to find the entry point in msvcrt.dll. I have tried this version on a win 7 machine and it's great, there's the usefull option for the entire copy of a page.
Any subgestion? Can i run this version on a XP Machine?
Thanks
Lorenzo
Re: Windows XP problem
I think, XP isn't longer supported ...
you could try with
https://download.qelectrotech.org/qet/t … st_x86.exe
Windows XP is supported, I patch Qt for this in my cross-compiler env:
https://github.com/mxe/mxe/issues/1394# … -239201213
still only by QElectroTech nomicons/grin
It's a little more work for me, but as long as it's possible for me, QElectroTech will support Windows XP for our users, and I think especially for those in education, schools and for all those in developing countries, or for those which not have money to buy a new machine or can't install Gnu/Linux and need to learn electricity, pneumatic, hydraulic, etc.. nomicons/smile
You are right, I tried and have the same issue.
Perhaps after update my cross environment to Qt 5.8
http://blog.qt.io/blog/2017/01/23/qt-5- … nt-1198905
Windows XP isn’t supported anymore as a target since Qt 5.7. If you need to continue supporting Windows XP, you must unfortunately stay with Qt 5.6.
Sorry !
But for the future release I can prepare a Windows XP compatible build.
Windows XP compatible :
https://download.qelectrotech.org/qet/b … ytouse.zip
Thank you so much, the portable version for xp of the 0.51 development is great. Thanks
Lorenzo
I have seen that opening a project created with the version 0.50, some lines and shapes, defined as "solid line" , are converted in dashed line. i have found this kind of difference using also win 7.
Thanks
Lorenzo
This is a known issue when a project was created with QET 0.5 and then edited with QET 0.51.
All OS's are concerned, this is a QET issue, not an OS issue.
You have to edit by yourself all dashed lines to make them solid again.
Yes, we changed the method to draw basic shapes and modify their XML attributes in the beginning of the version 0.51 devel for more functions and features:
https://qelectrotech.org/forum/viewtopi … 4353#p4353
Thank you, the problem for the future doesn't exist 'cause now i'm able to use the 0.51.
Lorenzo
XP compatibility is great to have.
There are times you need XP for old programs needed by some old hardware in machines to service/rebuild, and it is good to be able to run QET on same system.  nomicons/smile
