0000335QElectroTechLibraries of elementspublic2025-12-11 09:05
Reportercbiro Assigned To
Status newResolutionopen
PlatformLinuxOSFedora KDE Plasma x86_64OS Version43
Product Version0.9
Summary0000335: Element library icons are black and almost invisible on dark OS themes
DescriptionWhen using a dark system theme (KDE Plasma with dark theme), the icons in the element library are always displayed in black color. This makes them completely invisible against the dark background.
For example, terminal symbols and other element icons cannot be seen at all when browsing the library with a dark theme enabled.
Expected behavior: Icons should adapt to the current theme (use light/white color on dark themes, or have transparent/inverted rendering).
Desktop Environment: KDE Plasma
Theme: Dark theme enabled
TagsNo tags attached.
Issue History
2025-12-09 07:38 cbiro New Issue
2025-12-09 07:38 cbiro File Added: Screenshot_20251209_073549.png
2025-12-11 09:04 scorpio810_mantis Note Added: 0000835
2025-12-11 09:05 scorpio810_mantis Note Edited: 0000835
