0000329 | QElectroTech | Diagram Editor | public | 2025-08-16 20:23 | 2025-08-19 16:09 |
Reporter | Enzo | Assigned To | |||
Priority | normal | Severity | major | Reproducibility | always |
Product Version | 0.100 | ||||
Summary | 0000329: About every 30 seconds, the software would freeze temporarily, then resume functioning. | ||||
Description | I have been using QElectroTech for many years and find it a very powerful tool. However, as my project files grew in size, I began to encounter a problem: approximately every 30 seconds, the software would freeze temporarily, then resume functioning. After some testing, I identified the cause of the problem in the automatic backup system, specifically in the XML conversion phase (QETProject::writeBackup()). To resolve this, I recompiled the program, changing the value of the BACKUP_INTERVAL variable from 2 minutes to 200 minutes. This way, the problem no longer occurs, and I can also manage large projects, including A0 format sheets. I would like to know if there is an alternative solution to this modification, perhaps configurable directly from the interface or through a settings file, without having to recompile the software each time. Translated with DeepL.com (free version) | ||||
See settings https://download.qelectrotech.org/qet/manual_0.7/build/preferences/settings_general_project.html ![]() Butl imited to 99 minutes in the GUI. |
https://github.com/qelectrotech/qelectrotech-source-mirror/commit/f43ce820524a957df451aa5325b2caee2ca509fd |
A0 format!!! wow if possible to see your project? |
That's it, you no longer need to compile the programme yourself, just install the latest version 0.100 from the website. Best regards, Laurent |
Hi Enzo changing the value of the BACKUP_INTERVAL variable from 2 minutes to 20 minutes. I think 200 minutes was so long for all users. Maybe use an Qprocess for KautoSaveFile or use an spinbox for user change timer depending on type of project. Fixed: https://github.com/qelectrotech/qelectrotech-source-mirror/commit/6375136a5097705259a2ef4289a33ddcc1df6ba4 Solari Saluti Laurent |
Fantastic, very powerful, this is the magic of open source, thank you and I hope to deepen my knowledge of the code as soon as possible so that I can actively help. Salutations ensoleillées Enzo |
2025-08-16 20:23 | Enzo | New Issue | |
2025-08-16 20:53 | scorpio810_mantis | Note Added: 0000813 | |
2025-08-16 20:54 | scorpio810_mantis | Note Edited: 0000813 | |
2025-08-16 20:56 | scorpio810_mantis | Note Edited: 0000813 | |
2025-08-17 08:49 | scorpio810_mantis | Note Edited: 0000813 | |
2025-08-17 08:49 | scorpio810_mantis | Note Added: 0000814 | |
2025-08-17 08:58 | scorpio810_mantis | Note Added: 0000815 | |
2025-08-17 09:26 | scorpio810_mantis | Note Added: 0000816 | |
2025-08-18 14:06 | scorpio810_mantis | Note Added: 0000819 | |
2025-08-18 17:04 | scorpio810_mantis | Note Edited: 0000819 | |
2025-08-19 16:09 | Enzo | Note Added: 0000820 |
