0000329QElectroTechDiagram Editorpublic2025-10-20 23:16
ReporterEnzo Assigned Toblack_sun
PrioritynormalSeveritymajorReproducibilityalways
Product Version0.100
Summary0000329: About every 30 seconds, the software would freeze temporarily, then resume functioning.
DescriptionI have been using QElectroTech for many years and find it a very powerful tool. However, as my project files grew in size, I began to encounter a problem: approximately every 30 seconds, the software would freeze temporarily, then resume functioning.
After some testing, I identified the cause of the problem in the automatic backup system, specifically in the XML conversion phase (QETProject::writeBackup()).
To resolve this, I recompiled the program, changing the value of the BACKUP_INTERVAL variable from 2 minutes to 200 minutes. This way, the problem no longer occurs, and I can also manage large projects, including A0 format sheets.
I would like to know if there is an alternative solution to this modification, perhaps configurable directly from the interface or through a settings file, without having to recompile the software each time.
Translated with DeepL.com (free version)
TagsNo tags attached.
Activities
scorpio810_mantis
2025-08-16 20:53
administrator   ~0000813
See settings
https://download.qelectrotech.org/qet/manual_0.7/build/preferences/settings_general_project.html
Butl imited to 99 minutes in the GUI.
scorpio810_mantis
2025-08-17 08:49
administrator   ~0000814
https://github.com/qelectrotech/qelectrotech-source-mirror/commit/f43ce820524a957df451aa5325b2caee2ca509fd
scorpio810_mantis
2025-08-17 08:58
administrator   ~0000815
A0 format!!! wow if possible to see your project?
scorpio810_mantis
2025-08-17 09:26
administrator   ~0000816
That's it, you no longer need to compile the programme yourself, just install the latest version 0.100 from the website.
Best regards,
scorpio810_mantis
2025-08-18 14:06
administrator   ~0000819
Hi Enzo
ok, I saw your folio was very heavy : ~ 650MB So
changing the value of the BACKUP_INTERVAL variable from 2 minutes to 20 minutes.
I think 200 minutes was so long for all users.
Maybe use an Qprocess for KautoSaveFile or use an spinbox for user change timer depending on type of project.
Fixed: https://github.com/qelectrotech/qelectrotech-source-mirror/commit/6375136a5097705259a2ef4289a33ddcc1df6ba4
Solari Saluti
Enzo
2025-08-19 16:09
reporter   ~0000820
Fantastic, very powerful, this is the magic of open source, thank you and I hope to deepen my knowledge of the code as soon as possible so that I can actively help.
Salutations ensoleillées
Enzo
Issue History
2025-08-16 20:23 Enzo New Issue
2025-08-16 20:53 scorpio810_mantis Note Added: 0000813
2025-08-16 20:54 scorpio810_mantis Note Edited: 0000813
2025-08-16 20:56 scorpio810_mantis Note Edited: 0000813
2025-08-17 08:49 scorpio810_mantis Note Edited: 0000813
2025-08-17 08:49 scorpio810_mantis Note Added: 0000814
2025-08-17 08:58 scorpio810_mantis Note Added: 0000815
2025-08-17 09:26 scorpio810_mantis Note Added: 0000816
2025-08-18 14:06 scorpio810_mantis Note Added: 0000819
2025-08-18 17:04 scorpio810_mantis Note Edited: 0000819
2025-08-19 16:09 Enzo Note Added: 0000820
2025-09-08 15:22 scorpio810_mantis Note Edited: 0000819
2025-10-20 23:16 black_sun Assigned To => black_sun
2025-10-20 23:16 black_sun Status new => resolved
2025-10-20 23:16 black_sun Resolution open => fixed
