0000296QElectroTechDiagram Editorpublic2026-08-11 12:58
ReporterFekete_Istvan_HU Assigned Toplc-user
Status closedResolutionfixed
PlatformLinuxOSUbuntuOS Version22.04
Summary0000296: Some master slave elements have reference / label overlap. Unableto see the reference value
DescriptionHello!
Thank You for You effort with my previous problem. Here is a minor bug in my project.
When link some master and slave elements the dynamically generated reference is overlapping with the label, and is unreadable. The affected elements are:
-Magneto thermal circuit breaker
-Thermal Relay NC
May i correct this issue?
Thank You for help!
Regards:
Steve from Hungary
TagsNo tags attached.
Activities
scorpio810_mantis
2024-01-16 18:04
administrator   ~0000691
Hello.
Please see https://qelectrotech.org/forum/viewtopic.php?pid=16790#p16790
Regards,
Fekete_Istvan_HU
2024-01-17 12:41
reporter   ~0000692
It escaped my attention that this error was already mentioned in the forum. The explanation in the forum post is a little bit foggy, but if you want to correct this error in your existing drawing, do the following:
1. Project/Project properties
2. New folio / Cross referencing tab
3. Select "Organ of protection" on upper first Type: listbox
4. Then click these settings:
   View contacts
   Under the label of the element
   Bottom (There was "Text alignment" setting, which does this strange overlapped Xreference)
5. Click OK
Now Your existing drawing will be corrected. Check all occurrences and correct the label positions if needed.
To avoid this issue in Your NEXT NEW project, do the same settings in the "Settings/Configure QElectrotech"
I think this is clear for everyone who have this same problem.
Thank You scorpio810 for help! :-)
scorpio810_mantis
2024-01-17 13:12
administrator   ~0000693
Thank you for your very clear explanations which can serve as references to help new users.
As this question comes up quite often, we should try to correct it in the code if possible.
To add to the todolist...on Wiki!
plc-user
2026-08-11 12:58
developer   ~0000853
Fixed in sources of 0.100.1-dev
Issue History
2024-01-16 16:32 Fekete_Istvan_HU New Issue
2024-01-16 16:32 Fekete_Istvan_HU File Added: Képernyőkép 2024-01-16 16-21-03.png
2024-01-16 16:32 Fekete_Istvan_HU File Added: Képernyőkép 2024-01-16 16-20-30.png
2024-01-16 18:04 scorpio810_mantis Note Added: 0000691
2024-01-16 18:04 scorpio810_mantis Note Edited: 0000691
2024-01-16 18:06 scorpio810_mantis Note Edited: 0000691
2024-01-17 12:41 Fekete_Istvan_HU Note Added: 0000692
2024-01-17 12:41 Fekete_Istvan_HU File Added: Képernyőkép 2024-01-17 10-47-37.png
2024-01-17 12:41 Fekete_Istvan_HU File Added: Képernyőkép 2024-01-17 10-48-02.png
2024-01-17 12:41 Fekete_Istvan_HU File Added: Képernyőkép 2024-01-17 12-33-13.png
2024-01-17 13:12 scorpio810_mantis Note Added: 0000693
2026-08-11 12:58 plc-user Assigned To => plc-user
2026-08-11 12:58 plc-user Status new => closed
2026-08-11 12:58 plc-user Resolution open => fixed
2026-08-11 12:58 plc-user Note Added: 0000853
