| 0000269 | QElectroTech | Element Editor | public | 2022-09-01 09:07 | 2025-02-11 19:31 |
| Reporter | plc-user | Assigned To | plc-user | ||
| Fixed in Version | 0.100 | ||||
| Summary | 0000269: Copy-and-Paste: Position of insertion depends on what elements are copied | ||||
| Description | Graphical elements (rect, circle, etc) are inserted at (x-position + integer offset), Text-Elements are inserted at an offset with float-number. If a graphical element is copied together with a text-element, both elements are placed with a float-offset, which is different from the offset, when only a text was copied. This is very annoying, because you can't fix this with the element-editor! Explanation, screenshot and a sample QET-file can be found here: https://qelectrotech.org/forum/viewtopic.php?id=2283 | ||||
| Steps To Reproduce | Mark element(s) and press <Ctrl>+c and <Ctrl>+v and see where the elements are placed. | ||||
Fixed by own Pull-Request at github: https://github.com/qelectrotech/qelectrotech-source-mirror/pull/351 |
Binary Packages are available at QET Downloads. |
| 2022-09-01 09:07 | plc-user | New Issue | |
| 2025-02-11 15:39 | plc-user | Note Added: 0000775 | |
| 2025-02-11 19:28 | plc-user | Assigned To | => plc-user |
| 2025-02-11 19:28 | plc-user | Status | new => assigned |
| 2025-02-11 19:31 | plc-user | Status | assigned => resolved |
| 2025-02-11 19:31 | plc-user | Resolution | open => fixed |
| 2025-02-11 19:31 | plc-user | Fixed in Version | => 0.100 |
| 2025-02-11 19:31 | plc-user | Note Added: 0000778 | |
| 2025-02-11 19:31 | plc-user | Status | resolved => closed |
