0000256QElectroTechDiagram Editorpublic2026-10-01 05:34
Reportermax Assigned To
Status newResolutionopen
PlatformAMD Ryzen 7 3700X OSDebianOS Version11
Summary0000256: composite text folio reference overlapped
DescriptionHello,
composite text from folio reference overlapped only on coming arrow, going arrow work as it should.
No matter how it is oriented in element editor and on diagram editor.
Steps To ReproduceAdd folio reference with going arrow, leftside alignment and composite text to diagram. Sometimes on open a saved project it moves all the same.
TagsNo tags attached.
01going_arrow_with_protocol.elmt (2,255 bytes)
<definition type="element" hotspot_y="10" width="70" version="0.80" link_type="next_report" height="20" hotspot_x="16">
    <uuid uuid="{b269a4c5-613a-46ee-8bcb-c0c3791ae931}"/>
    <names>
        <name lang="de">Nächste Folie</name>
    </names>
    <description>
        <polygon y2="3" antialias="true" x1="-1" y1="-3" x4="-1" style="line-style:normal;line-weight:normal;filling:black;color:black" x3="9" x2="-1" y4="-3" y3="0"/>
        <rect antialias="false" x="0" y="-5" rx="0" style="line-style:normal;line-weight:normal;filling:none;color:none" ry="0" width="50" height="10"/>
        <dynamic_text x="10" y="-10" frame="false" font="FreeMono,9,-1,5,50,0,0,0,0,0" Halignment="AlignLeft" rotation="0" text_width="-1" z="3" uuid="{170dbfda-3678-43db-9649-515301d344c3}" text_from="CompositeText" Valignment="AlignVCenter">
            <text> / </text>
            <info_name>label</info_name>
            <composite_text>%{function} / %{label}</composite_text>
        </dynamic_text>
        <dynamic_text x="-10" y="0" frame="false" font="FreeMono,7,-1,5,50,0,0,0,0,0" Halignment="AlignRight" rotation="0" text_width="-1" z="4" uuid="{583a7eec-9232-43c4-8fed-34ea092dac7f}" text_from="ElementInfo" Valignment="AlignTop">
            <text></text>
            <info_name>tension_protocol</info_name>
        </dynamic_text>
        <dynamic_text x="-205" y="-20" frame="false" font="FreeMono,7,-1,5,50,0,0,0,0,0" Halignment="AlignRight" rotation="0" text_width="-1" z="4" uuid="{583a7eec-9232-43c4-8fed-34ea092dac7f}" text_from="CompositeText" Valignment="AlignBottom">
            <text>%{conductor_color} %{conductor_section}</text>
            <composite_text>%{conductor_color} %{conductor_section}</composite_text>
        </dynamic_text>
        <line y2="0" antialias="false" x1="0" y1="0" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" end1="none" x2="-10" length1="1.5" length2="1.5"/>
        <terminal x="-10" y="0" orientation="w" name="" uuid="{9b0a7ce3-c32f-4986-a2b4-3da850a13233}"/>
    </description>
</definition>
Relationships
related to 0000226 new Alignemt on right-sided composite text wrong
Activities
scorpio810_mantis
2022-02-16 14:33
administrator   ~0000541
you don't send coming arrow element
max
2022-02-17 17:58
reporter   ~0000542
Sorry, now the right one.
02coming_arrow.elmt (2,729 bytes)
<definition hotspot_x="4" hotspot_y="5" type="element" width="30" height="10" link_type="previous_report" version="0.90">
    <uuid uuid="{0d5dd917-3593-4b1c-92dd-be305a380cb9}"/>
    <names>
        <name lang="ar">الصفحة السابقة</name>
        <name lang="de">Vorherige Folie</name>
        <name lang="pl">Wejście adresowe</name>
        <name lang="it">Foglio precedente</name>
        <name lang="ru">Предыдущая страница</name>
        <name lang="es">folio anterior</name>
        <name lang="nl">Referentie Vorig</name>
        <name lang="el">Προηγούμενη σελίδα</name>
        <name lang="cs">Předchozí list</name>
        <name lang="en">Coming arrow</name>
        <name lang="fr">Folio précédent</name>
    </names>
    <description>
        <dynamic_text keep_visual_rotation="true" x="-32" z="1" frame="false" text_width="-1" font="FreeMono,9,-1,5,50,0,0,0,0,0" Valignment="AlignVCenter" Halignment="AlignRight" uuid="{a00537f9-f796-4c78-88b0-0d8c681aaff9}" y="-10" rotation="0" text_from="CompositeText">
            <text> / </text>
            <composite_text>%{label} / %{function}</composite_text>
        </dynamic_text>
        <polygon y2="3" y3="0" x2="-1" y1="-3" x1="-1" x4="-1" style="line-style:normal;line-weight:normal;filling:black;color:black" x3="9" y4="-3" antialias="true"/>
        <line y2="0" end2="none" x2="20" y1="0" x1="8" end1="none" style="line-style:normal;line-weight:normal;filling:none;color:black" length2="1.5" length1="1.5" antialias="false"/>
        <dynamic_text keep_visual_rotation="true" x="10" z="5" frame="false" text_width="-1" font="FreeMono,7,-1,5,50,0,0,0,0,0" Valignment="AlignBottom" Halignment="AlignLeft" uuid="{edd6760a-9912-4ee7-9e18-9be67083dead}" y="-20" rotation="0" text_from="CompositeText">
            <info_name>conductor_section</info_name>
        </dynamic_text>
        <dynamic_text keep_visual_rotation="false" x="10" z="5" frame="false" text_width="-1" font="FreeMono,7,-1,5,50,0,0,0,0,0" Valignment="AlignTop" Halignment="AlignLeft" uuid="{edd6760a-9912-4ee7-9e18-9be67083dead}" y="0" rotation="0" text_from="ElementInfo">
            <text></text>
        </dynamic_text>
        <terminal x="20" type="Generic" name="" orientation="e" uuid="{6b6aed62-d6d2-48ad-a4f3-256d96d04592}" y="0"/>
    </description>
</definition>
ispyisail
2026-10-01 05:34
developer   ~0000925
I can't reproduce this on master as of August 2026. It is the same report as GitHub issue 0000210: https://github.com/qelectrotech/qelectrotech-source-mirror/issues/210
I used both elements attached here, 01going_arrow_with_protocol.elmt and 02coming_arrow.elmt. Placing them, linking them, saving and reopening, and copying and pasting all show the text in the right place. When the coming arrow is linked, its right-aligned text grows and moves left by the right amount.
The likely fix is achim's two commits from August 2025, 0a6efa466 and 73ce3ae9f. They fixed right-aligned text in folio report arrows being shifted by its own width.
If a recent build still shows the overlap, please attach the project file.
Issue History
2022-02-11 15:57 max New Issue
2022-02-11 15:57 max File Added: Bildschirmfoto von 2022-02-10 19-28-17.png
2022-02-11 15:57 max File Added: 01going_arrow_with_protocol.elmt
2022-02-11 15:59 max Relationship added related to 0000226
2022-02-16 14:33 scorpio810_mantis Note Added: 0000541
2022-02-17 17:59 max Note Added: 0000542
2022-02-17 17:59 max File Added: 02coming_arrow.elmt
2026-10-01 05:34 ispyisail Note Added: 0000925
