0000256 | QElectroTech | Diagram Editor | public | 2022-02-11 15:57 | 2022-02-17 17:59 |
Reporter | max | Assigned To | |||
Platform | AMD Ryzen 7 3700X | OS | Debian | OS Version | 11 |
Summary | 0000256: composite text folio reference overlapped | ||||
Description | Hello, composite text from folio reference overlapped only on coming arrow, going arrow work as it should. No matter how it is oriented in element editor and on diagram editor. | ||||
Steps To Reproduce | Add folio reference with going arrow, leftside alignment and composite text to diagram. Sometimes on open a saved project it moves all the same. | ||||
Attached Files | 01going_arrow_with_protocol.elmt (2,255 bytes)
<definition type="element" hotspot_y="10" width="70" version="0.80" link_type="next_report" height="20" hotspot_x="16"> <uuid uuid="{b269a4c5-613a-46ee-8bcb-c0c3791ae931}"/> <names> <name lang="de">Nächste Folie</name> </names> <informations>Author: The QElectroTech team License: see http://qelectrotech.org/wiki/doc/elements_license</informations> <description> <polygon y2="3" antialias="true" x1="-1" y1="-3" x4="-1" style="line-style:normal;line-weight:normal;filling:black;color:black" x3="9" x2="-1" y4="-3" y3="0"/> <rect antialias="false" x="0" y="-5" rx="0" style="line-style:normal;line-weight:normal;filling:none;color:none" ry="0" width="50" height="10"/> <dynamic_text x="10" y="-10" frame="false" font="FreeMono,9,-1,5,50,0,0,0,0,0" Halignment="AlignLeft" rotation="0" text_width="-1" z="3" uuid="{170dbfda-3678-43db-9649-515301d344c3}" text_from="CompositeText" Valignment="AlignVCenter"> <text> / </text> <info_name>label</info_name> <composite_text>%{function} / %{label}</composite_text> </dynamic_text> <dynamic_text x="-10" y="0" frame="false" font="FreeMono,7,-1,5,50,0,0,0,0,0" Halignment="AlignRight" rotation="0" text_width="-1" z="4" uuid="{583a7eec-9232-43c4-8fed-34ea092dac7f}" text_from="ElementInfo" Valignment="AlignTop"> <text></text> <info_name>tension_protocol</info_name> </dynamic_text> <dynamic_text x="-205" y="-20" frame="false" font="FreeMono,7,-1,5,50,0,0,0,0,0" Halignment="AlignRight" rotation="0" text_width="-1" z="4" uuid="{583a7eec-9232-43c4-8fed-34ea092dac7f}" text_from="CompositeText" Valignment="AlignBottom"> <text>%{conductor_color} %{conductor_section}</text> <info_name>tension_protocol</info_name> <composite_text>%{conductor_color} %{conductor_section}</composite_text> </dynamic_text> <line y2="0" antialias="false" x1="0" y1="0" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" end1="none" x2="-10" length1="1.5" length2="1.5"/> <terminal x="-10" y="0" orientation="w" name="" uuid="{9b0a7ce3-c32f-4986-a2b4-3da850a13233}"/> </description> </definition> | ||||
related to | 0000226 | new | Alignemt on right-sided composite text wrong |
Hi, you don't send coming arrow element |
Sorry, now the right one. 02coming_arrow.elmt (2,729 bytes)
<definition hotspot_x="4" hotspot_y="5" type="element" width="30" height="10" link_type="previous_report" version="0.90"> <uuid uuid="{0d5dd917-3593-4b1c-92dd-be305a380cb9}"/> <names> <name lang="ar">الصفحة السابقة</name> <name lang="de">Vorherige Folie</name> <name lang="pl">Wejście adresowe</name> <name lang="it">Foglio precedente</name> <name lang="ru">Предыдущая страница</name> <name lang="es">folio anterior</name> <name lang="nl">Referentie Vorig</name> <name lang="el">Προηγούμενη σελίδα</name> <name lang="cs">Předchozí list</name> <name lang="en">Coming arrow</name> <name lang="fr">Folio précédent</name> </names> <informations>Author: The QElectroTech team License: see http://qelectrotech.org/wiki/doc/elements_license</informations> <description> <dynamic_text keep_visual_rotation="true" x="-32" z="1" frame="false" text_width="-1" font="FreeMono,9,-1,5,50,0,0,0,0,0" Valignment="AlignVCenter" Halignment="AlignRight" uuid="{a00537f9-f796-4c78-88b0-0d8c681aaff9}" y="-10" rotation="0" text_from="CompositeText"> <text> / </text> <info_name>label</info_name> <composite_text>%{label} / %{function}</composite_text> </dynamic_text> <polygon y2="3" y3="0" x2="-1" y1="-3" x1="-1" x4="-1" style="line-style:normal;line-weight:normal;filling:black;color:black" x3="9" y4="-3" antialias="true"/> <line y2="0" end2="none" x2="20" y1="0" x1="8" end1="none" style="line-style:normal;line-weight:normal;filling:none;color:black" length2="1.5" length1="1.5" antialias="false"/> <dynamic_text keep_visual_rotation="true" x="10" z="5" frame="false" text_width="-1" font="FreeMono,7,-1,5,50,0,0,0,0,0" Valignment="AlignBottom" Halignment="AlignLeft" uuid="{edd6760a-9912-4ee7-9e18-9be67083dead}" y="-20" rotation="0" text_from="CompositeText"> <text>%{conductor_color} %{conductor_section}</text> <info_name>conductor_section</info_name> <composite_text>%{conductor_color} %{conductor_section}</composite_text> </dynamic_text> <dynamic_text keep_visual_rotation="false" x="10" z="5" frame="false" text_width="-1" font="FreeMono,7,-1,5,50,0,0,0,0,0" Valignment="AlignTop" Halignment="AlignLeft" uuid="{edd6760a-9912-4ee7-9e18-9be67083dead}" y="0" rotation="0" text_from="ElementInfo"> <text></text> <info_name>tension_protocol</info_name> </dynamic_text> <terminal x="20" type="Generic" name="" orientation="e" uuid="{6b6aed62-d6d2-48ad-a4f3-256d96d04592}" y="0"/> </description> </definition> |
2022-02-11 15:57 | max | New Issue | |
2022-02-11 15:57 | max | File Added: Bildschirmfoto von 2022-02-10 19-28-17.png | |
2022-02-11 15:57 | max | File Added: 01going_arrow_with_protocol.elmt | |
2022-02-11 15:59 | max | Relationship added | related to 0000226 |
2022-02-16 14:33 | scorpio810_mantis | Note Added: 0000541 | |
2022-02-17 17:59 | max | Note Added: 0000542 | |
2022-02-17 17:59 | max | File Added: 02coming_arrow.elmt |
