| 0000193 | QElectroTech | website | public | 2020-07-14 09:53 | 2026-10-01 05:12 |
| Reporter | rpaolo538 | Assigned To | |||
| Priority | normal | Severity | block | Reproducibility | always |
| Summary | 0000193: Error in italian traslate | ||||
| Description | in italian version I found under Generale/progetti - Sentence in francais: " Position de la liste des....." - Word non correct "Salvatoaggio", word correct is "Salvataggio" without "o" | ||||
| Steps To Reproduce | COnfigurazione/configura Electrotech/ Generale/ Progetti | ||||
| Attached Files | |||||
You could help Silvio for translation if you know GIT a little. |
Happy to help you, I will learn GIT.. |
An easy solution is to get latest source on Github https://github.com/qelectrotech/qelectrotech-source-mirror Get qtcreator for your OS : https://download.qt.io/official_releases/qtcreator/4.12/4.12.0/ Open lang folder in QET and click on qet_it.ts file is open qtlinguist https://doc.qt.io/archives/qt-4.8/linguist-translators.html https://doc.qt.io/qt-5/linguist-translators.html Comment to translate are in french in code you could help you with open english translation tab to see english comment translated After translate, save and publish and send me qet_it.ts and qet_it.qm files. |
Because this ticket has been open for quite a while, I assume rpaolo538 didn't have the time to do the correction himself. So, when preparing a new German language file I corrected this issue in the Italian language file as well. It is part of Pull Request 0000090 and ready to be merged for the next Nightly. |
Issue is solved in current nightlies. Ticket can be closed now. |
Bisku corrected this in 2020 (PR 0000090). The current Italian translation no longer contains "Salvatoaggio". Closing. If you still see a wrong or French text in Italian, please open a new entry with a screenshot. |
| 2020-07-14 09:53 | rpaolo538 | New Issue | |
| 2020-07-14 09:53 | rpaolo538 | File Added: Cattura.JPG | |
| 2020-07-14 13:05 | scorpio810_mantis | Note Added: 0000427 | |
| 2020-07-14 13:33 | rpaolo538 | Note Added: 0000428 | |
| 2020-07-14 13:53 | scorpio810_mantis | Note Added: 0000429 | |
| 2020-11-15 09:42 | Bisku | Note Added: 0000464 | |
| 2020-12-05 16:36 | Bisku | Note Added: 0000471 | |
| 2021-02-15 00:44 |
Product Version | => 0.8 |
| 2021-02-15 00:45 |
| 2021-02-15 00:47 |
| 2021-02-15 00:53 |
Category | translation => website |
| 2021-02-15 00:54 |
Severity | text => block |
| 2026-10-01 05:12 | ispyisail | Note Added: 0000920 | |
| 2026-10-01 05:12 | ispyisail | Status | new => resolved |
| 2026-10-01 05:12 | ispyisail | Resolution | open => fixed |
