0000193QElectroTechwebsitepublic2021-02-15 00:54
Reporterrpaolo538 Assigned To
PrioritynormalSeverityblockReproducibilityalways
Status newResolutionopen
Summary0000193: Error in italian traslate
Descriptionin italian version I found under Generale/progetti
- Sentence in francais: " Position de la liste des....."
- Word non correct "Salvatoaggio", word correct is "Salvataggio" without "o"
Steps To ReproduceCOnfigurazione/configura Electrotech/ Generale/ Progetti
TagsNo tags attached.
Activities
scorpio810_mantis
2020-07-14 13:05
administrator   ~0000427
You could help Silvio for translation if you know GIT a little.
rpaolo538
2020-07-14 13:33
reporter   ~0000428
Happy to help you, I will learn GIT..
scorpio810_mantis
2020-07-14 13:53
administrator   ~0000429
An easy solution is to get latest source on Github
https://github.com/qelectrotech/qelectrotech-source-mirror
Get qtcreator for your OS :
https://download.qt.io/official_releases/qtcreator/4.12/4.12.0/
Open lang folder in QET and click on qet_it.ts file is open qtlinguist
https://doc.qt.io/archives/qt-4.8/linguist-translators.html
https://doc.qt.io/qt-5/linguist-translators.html
Comment to translate are in french in code you could help you with open english translation tab to see english comment translated
After translate, save and publish and send me qet_it.ts and qet_it.qm files.
Bisku
2020-11-15 09:42
reporter   ~0000464
Because this ticket has been open for quite a while, I assume rpaolo538 didn't have the time to do the correction himself. So, when preparing a new German language file I corrected this issue in the Italian language file as well. It is part of Pull Request 0000090 and ready to be merged for the next Nightly.
Bisku
2020-12-05 16:36
reporter   ~0000471
Issue is solved in current nightlies. Ticket can be closed now.
Issue History
2020-07-14 09:53 rpaolo538 New Issue
2020-07-14 09:53 rpaolo538 File Added: Cattura.JPG
2020-07-14 13:05 scorpio810_mantis Note Added: 0000427
2020-07-14 13:33 rpaolo538 Note Added: 0000428
2020-07-14 13:53 scorpio810_mantis Note Added: 0000429
2020-11-15 09:42 Bisku Note Added: 0000464
2020-12-05 16:36 Bisku Note Added: 0000471
2021-02-15 00:44 user245 Product Version => 0.8
2021-02-15 00:47 user245 Product Version 0.8 => SVN/trunk
2021-02-15 00:53 user245 Category translation => website
2021-02-15 00:54 user245 Severity text => block
