| 0000153 | QElectroTech | website | public | 2018-02-06 16:30 | 2021-02-15 00:48 |
| Reporter | gabberworld | Assigned To | black_sun_2012 | ||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | assigned | Resolution | reopened | ||
| Platform | 64 | OS | windows | OS Version | 10 |
| Summary | 0000153: DXF Export | ||||
| Description | it makes the text and other stuff double in dxf file it also not disable bolders and titles when i select them, for that i made patch | ||||
| Attached Files | exportdialog.cpp.patch (1,385 bytes)
Index: exportdialog.cpp
--- exportdialog.cpp (revision 5229)
+++ exportdialog.cpp (working copy)
@@ -398,6 +398,7 @@
@param io_device Peripherique de sortie pour le code DXF (souvent : un fichier)
void ExportDialog::generateDxf(Diagram *diagram, int width, int height, bool keep_aspect_ratio, QString &file_path) {
+ saveReloadDiagramParameters(diagram, true);
project_ -> setFilePath(file_path);
@@ -410,8 +411,10 @@
Createdxf::dxfBegin(file_path);
//Add project elements (lines, rectangles, circles, texts) to dxf file
- Createdxf::drawRectangle(file_path, 0, 0, double(width)*Createdxf::xScale, double(height)*Createdxf::yScale, 0);
- diagram -> border_and_titleblock.drawDxf(width, height, keep_aspect_ratio, file_path, 0);
+ if (epw -> exportProperties().draw_border) {
+ Createdxf::drawRectangle(file_path, 0, 0, double(width)*Createdxf::xScale, double(height)*Createdxf::yScale, 0);
+ diagram -> border_and_titleblock.drawDxf(width, height, keep_aspect_ratio, file_path, 0);
// Build the lists of elements.
QList<Element *> list_elements;
@@ -677,6 +680,8 @@
Createdxf::dxfEnd(file_path);
+ saveReloadDiagramParameters(diagram, false);
void ExportDialog::fillRow(QString file_path, const QRectF &row_rect, QString author, QString title,
what i find out that probem starts at customelement.cpp in line 190 it generates double elements at there with parseElement |
Patch for some colors inside dxf dxf.color.patch (7,876 bytes)
Index: createdxf.cpp
--- createdxf.cpp (revision 5237)
+++ createdxf.cpp (working copy)
@@ -323,7 +323,92 @@
+long Createdxf::RGBcodeTable[255]{
+ 0x000000, 0xff0000, 0xffff00, 0x00ff00, 0x00ffff,
+ 0x0000ff, 0xff00ff, 0xffffff, 0x414141, 0x808080,
+ 0xff0000, 0xffaaaa, 0xbd0000, 0xbd7e7e, 0x810000,
+ 0x815656, 0x680000, 0x684545, 0x4f0000, 0x4f3535,
+ 0xff3f00, 0xffbfaa, 0xbd2e00, 0xbd8d7e, 0x811f00,
+ 0x816056, 0x681900, 0x684e45, 0x4f1300, 0x4f3b35,
+ 0xff7f00, 0xffd4aa, 0xbd5e00, 0xbd9d7e, 0x814000,
+ 0x816b56, 0x683400, 0x685645, 0x4f2700, 0x4f4235,
+ 0xffbf00, 0xffeaaa, 0xbd8d00, 0xbdad7e, 0x816000,
+ 0x817656, 0x684e00, 0x685f45, 0x4f3b00, 0x4f4935,
+ 0xffff00, 0xffffaa, 0xbdbd00, 0xbdbd7e, 0x818100,
+ 0x818156, 0x686800, 0x686845, 0x4f4f00, 0x4f4f35,
+ 0xbfff00, 0xeaffaa, 0x8dbd00, 0xadbd7e, 0x608100,
+ 0x768156, 0x4e6800, 0x5f6845, 0x3b4f00, 0x494f35,
+ 0x7fff00, 0xd4ffaa, 0x5ebd00, 0x9dbd7e, 0x408100,
+ 0x6b8156, 0x346800, 0x566845, 0x274f00, 0x424f35,
+ 0x3fff00, 0xbfffaa, 0x2ebd00, 0x8dbd7e, 0x1f8100,
+ 0x608156, 0x196800, 0x4e6845, 0x134f00, 0x3b4f35,
+ 0x00ff00, 0xaaffaa, 0x00bd00, 0x7ebd7e, 0x008100,
+ 0x568156, 0x006800, 0x456845, 0x004f00, 0x354f35,
+ 0x00ff3f, 0xaaffbf, 0x00bd2e, 0x7ebd8d, 0x00811f,
+ 0x568160, 0x006819, 0x45684e, 0x004f13, 0x354f3b,
+ 0x00ff7f, 0xaaffd4, 0x00bd5e, 0x7ebd9d, 0x008140,
+ 0x56816b, 0x006834, 0x456856, 0x004f27, 0x354f42,
+ 0x00ffbf, 0xaaffea, 0x00bd8d, 0x7ebdad, 0x008160,
+ 0x568176, 0x00684e, 0x45685f, 0x004f3b, 0x354f49,
+ 0x00ffff, 0xaaffff, 0x00bdbd, 0x7ebdbd, 0x008181,
+ 0x568181, 0x006868, 0x456868, 0x004f4f, 0x354f4f,
+ 0x00bfff, 0xaaeaff, 0x008dbd, 0x7eadbd, 0x006081,
+ 0x567681, 0x004e68, 0x455f68, 0x003b4f, 0x35494f,
+ 0x007fff, 0xaad4ff, 0x005ebd, 0x7e9dbd, 0x004081,
+ 0x566b81, 0x003468, 0x455668, 0x00274f, 0x35424f,
+ 0x003fff, 0xaabfff, 0x002ebd, 0x7e8dbd, 0x001f81,
+ 0x566081, 0x001968, 0x454e68, 0x00134f, 0x353b4f,
+ 0x0000ff, 0xaaaaff, 0x0000bd, 0x7e7ebd, 0x000081,
+ 0x565681, 0x000068, 0x454568, 0x00004f, 0x35354f,
+ 0x3f00ff, 0xbfaaff, 0x2e00bd, 0x8d7ebd, 0x1f0081,
+ 0x605681, 0x190068, 0x4e4568, 0x13004f, 0x3b354f,
+ 0x7f00ff, 0xd4aaff, 0x5e00bd, 0x9d7ebd, 0x400081,
+ 0x6b5681, 0x340068, 0x564568, 0x27004f, 0x42354f,
+ 0xbf00ff, 0xeeaaff, 0x8d00bd, 0xad7ebd, 0x600081,
+ 0x765681, 0x4e0068, 0x5f4568, 0x3b004f, 0x49354f,
+ 0xff00ff, 0xffaaff, 0xbd00bd, 0xbd7ebd, 0x810081,
+ 0x815681, 0x680068, 0x684568, 0x4f004f, 0x4f354f,
+ 0xff00bf, 0xffaaea, 0xbd008d, 0xbd7ead, 0x810060,
+ 0x815676, 0x68004e, 0x68455f, 0x4f003b, 0x4f3549,
+ 0xff007f, 0xffaad4, 0xbd005e, 0xbd7e9d, 0x810040,
+ 0x81566b, 0x680034, 0x684556, 0x4f0027, 0x4f3542,
+ 0xff003f, 0xffaabf, 0xbd002e, 0xbd7e8d, 0x81001f,
+ 0x815660, 0x680019, 0x68454e, 0x4f0013, 0x4f353b,
+ 0x333333, 0x505050, 0x696969, 0x828282, 0xbebebe
+ * @brief Createdxf::getcolorCode
+ * This function returns the ACI color which is the "nearest" color to
+ * the color defined by the red, green and blue (RGB) values passed
+ * in argument.
+ * @param red
+ * @param green
+ * @param blue
+int Createdxf::getcolorCode (const long red, const long green, const long blue)
+ long acirgb, r,g,b;
+ long mindst = 2147483647L;
+ long dst = 0;
+ int minndx = 0;
+ for ( int i = 0; i < 254; i++ )
+ acirgb = RGBcodeTable[i];
+ b = ( acirgb & 0xffL );
+ g = ( acirgb & 0xff00L ) >> 8;
+ r = acirgb >> 16;
+ dst = abs ( r-red) + abs ( g -green) + abs (b-blue);
+ if ( dst < mindst )
+ minndx = i;
+ mindst = dst;
+ return minndx;
* @brief Createdxf::drawLine
* Conveniance function to draw line
* @param filepath
Index: createdxf.h
--- createdxf.h (revision 5237)
+++ createdxf.h (working copy)
@@ -48,7 +48,11 @@
static void drawText(QString,QString,double,double,double,double,int);
static void drawTextAligned(QString fileName, QString text,double x, double y, double height, double rotation, double oblique,int hAlign, int vAlign, double xAlign, int colour, bool leftAlign = false, float scale = 0);
- static const double sheetWidth;
+ static int getcolorCode (const long red, const long green, const long blue);
+ static long RGBcodeTable[];
+ static const double sheetWidth;
static const double sheetHeight;
static double xScale;
static double yScale;
--- exportdialog.cpp (revision 5237)
@@ -483,7 +483,7 @@
- foreach (QetShapeItem *qsi, list_shapes) qsi->toDXF(file_path);
+ foreach (QetShapeItem *qsi, list_shapes) qsi->toDXF(file_path, qsi->pen());
//Draw elements
foreach(Element *elmt, list_elements) {
Index: qetgraphicsitem/qetshapeitem.cpp
--- qetgraphicsitem/qetshapeitem.cpp (revision 5237)
+++ qetgraphicsitem/qetshapeitem.cpp (working copy)
@@ -666,13 +666,14 @@
* @param filepath file path of the the dxf document
* @return true if draw success
-bool QetShapeItem::toDXF(const QString &filepath)
+bool QetShapeItem::toDXF(const QString &filepath,const QPen &pen)
- switch (m_shapeType)
+ switch (m_shapeType)
- case Line: Createdxf::drawLine (filepath, QLineF(mapToScene(m_P1), mapToScene(m_P2)), 0); return true;
- case Rectangle: Createdxf::drawRectangle(filepath, QRectF(mapToScene(m_P1), mapToScene(m_P2)).normalized(), 0); return true;
- case Ellipse: Createdxf::drawEllipse (filepath, QRectF(mapToScene(m_P1), mapToScene(m_P2)).normalized(), 0); return true;
+ case Line: Createdxf::drawLine (filepath, QLineF(mapToScene(m_P1), mapToScene(m_P2)), Createdxf::getcolorCode(pen.color().red(),pen.color().green(),pen.color().blue())); return true;
+ case Rectangle: Createdxf::drawRectangle(filepath, QRectF(mapToScene(m_P1), mapToScene(m_P2)).normalized(), Createdxf::getcolorCode(pen.color().red(),pen.color().green(),pen.color().blue())); return true;
+ case Ellipse: Createdxf::drawEllipse (filepath, QRectF(mapToScene(m_P1), mapToScene(m_P2)).normalized(), Createdxf::getcolorCode(pen.color().red(),pen.color().green(),pen.color().blue())); return true;
default: return false;
Index: qetgraphicsitem/qetshapeitem.h
--- qetgraphicsitem/qetshapeitem.h (revision 5237)
+++ qetgraphicsitem/qetshapeitem.h (working copy)
@@ -71,7 +71,7 @@
virtual bool fromXml (const QDomElement &);
virtual QDomElement toXml (QDomDocument &document) const;
- virtual bool toDXF (const QString &filepath);
+ virtual bool toDXF (const QString &filepath,const QPen &pen);
void editProperty() override;
QString name() const override;
Added, thanks. |
it's not fixed yet. i have no idea what for is used the parseElement(qde, low_zoom_qp); soo there not have patch yet for that from me |
[19:40] <joshua> in custom item [19:40] <joshua> There are two QPixmaps [19:40] <joshua> QPicture [19:40] <joshua> one for the normal zoom [19:40] <joshua> and another for the low zoom [19:41] <scorpio810> ah? ok [19:41] <joshua> // Init the QPainter for draw the elemennt [19:41] <joshua> QPainter qp; [19:41] <joshua> qp.begin (& drawing); [19:41] <joshua> QPainter low_zoom_qp; [19:41] <joshua> low_zoom_qp.begin (& low_zoom_drawing); [19:41] <joshua> QPen tmp; [19:41] <joshua> tmp.setWidthF (1.0); // Vaudoo line to take into account the setCosmetic - do not remove [19:41] <joshua> tmp.setCosmetic (true); [19:41] <joshua> low_zoom_qp.setPen (tmp); [19:41] <joshua> voila the difference [19:42] <joshua> drawing is the normal [19:42] <joshua> and low_zoom_drawing, as are indicated |
not fixed, all custom elements double |
parseElement self loads element to element list if you call parseElement 2 times then it loads all elements 2 times |
Patch for that issue. qetgraphicsitem.patch (12,180 bytes)
Index: customelement.cpp
--- customelement.cpp (revision 5253)
+++ customelement.cpp (working copy)
@@ -189,14 +189,15 @@
if (parseElement(qde, qp))
- ++ parsed_elements_count;
- QString current_tag = qde.tagName();
- if (current_tag != "terminal" && current_tag != "input" && current_tag != DynamicElementTextItem::xmlTaggName())
- forbid_antialiasing = true;
- parseElement(qde, low_zoom_qp);
+ ++ parsed_elements_count;
+ QString current_tag = qde.tagName();
+ if (current_tag != "terminal" && current_tag != "input" && current_tag != DynamicElementTextItem::xmlTaggName())
+ forbid_antialiasing = true;
+ parseElement(qde, low_zoom_qp, false);
forbid_antialiasing = false;
else
@@ -211,7 +212,7 @@
//End of the drawing
qp.end();
- low_zoom_qp.end();
+ low_zoom_qp.end();
//They must be at least one parsed graphics part
@@ -299,11 +300,11 @@
@param options Les options graphiques
void CustomElement::paint(QPainter *qp, const QStyleOptionGraphicsItem *options) {
- if (options && options -> levelOfDetail < 1.0) {
- low_zoom_drawing.play(qp);
- } else {
- drawing.play(qp);
+ if (options && options -> levelOfDetail < 1.0) {
+ low_zoom_drawing.play(qp);
+ } else {
+ drawing.play(qp);
@@ -318,16 +319,16 @@
@param qp Le QPainter a utiliser pour dessiner l'element perso
@return true si l'analyse reussit, false sinon
-bool CustomElement::parseElement(QDomElement &e, QPainter &qp)
+bool CustomElement::parseElement(QDomElement &e, QPainter &qp, bool addtolist)
if (e.tagName() == "terminal") return(parseTerminal(e));
- else if (e.tagName() == "line") return(parseLine(e, qp));
- else if (e.tagName() == "rect") return(parseRect(e, qp));
- else if (e.tagName() == "ellipse") return(parseEllipse(e, qp));
- else if (e.tagName() == "circle") return(parseCircle(e, qp));
- else if (e.tagName() == "arc") return(parseArc(e, qp));
- else if (e.tagName() == "polygon") return(parsePolygon(e, qp));
- else if (e.tagName() == "text") return(parseText(e, qp));
+ else if (e.tagName() == "line") return(parseLine(e, qp, addtolist));
+ else if (e.tagName() == "rect") return(parseRect(e, qp, addtolist));
+ else if (e.tagName() == "ellipse") return(parseEllipse(e, qp, addtolist));
+ else if (e.tagName() == "circle") return(parseCircle(e, qp, addtolist));
+ else if (e.tagName() == "arc") return(parseArc(e, qp, addtolist));
+ else if (e.tagName() == "polygon") return(parsePolygon(e, qp, addtolist));
+ else if (e.tagName() == "text") return(parseText(e, qp, addtolist));
else if (e.tagName() == "input") return(parseInput(e));
else if (e.tagName() == "dynamic_text") return(parseDynamicText(e));
else return(true);
@@ -344,7 +345,7 @@
-bool CustomElement::parseLine(QDomElement &e, QPainter &qp) {
+bool CustomElement::parseLine(QDomElement &e, QPainter &qp, bool addtolist) {
// verifie la presence et la validite des attributs obligatoires
qreal x1, y1, x2, y2;
if (!QET::attributeIsAReal(e, QString("x1"), &x1)) return(false);
@@ -366,9 +367,11 @@
QLineF line(x1, y1, x2, y2);
+ if (addtolist){
//Add line to the list
- QLineF *newLine = new QLineF(line);
- m_lines << newLine;
+ QLineF *newLine = new QLineF(line);
+ m_lines << newLine;
QPointF point1(line.p1());
QPointF point2(line.p2());
@@ -458,7 +461,7 @@
-bool CustomElement::parseRect(QDomElement &e, QPainter &qp) {
+bool CustomElement::parseRect(QDomElement &e, QPainter &qp, bool addtolist) {
// verifie la presence des attributs obligatoires
qreal rect_x, rect_y, rect_w, rect_h;
if (!QET::attributeIsAReal(e, QString("x"), &rect_x)) return(false);
@@ -466,9 +469,11 @@
if (!QET::attributeIsAReal(e, QString("width"), &rect_w)) return(false);
if (!QET::attributeIsAReal(e, QString("height"), &rect_h)) return(false);
- //Add rectangle to the list
- QRectF *rect = new QRectF(rect_x, rect_y, rect_w, rect_h);
- m_rectangles << rect;
+ if (addtolist){
+ //Add rectangle to the list
+ QRectF *rect = new QRectF(rect_x, rect_y, rect_w, rect_h);
+ m_rectangles << rect;
qp.save();
setPainterStyle(e, qp);
@@ -495,7 +500,7 @@
-bool CustomElement::parseCircle(QDomElement &e, QPainter &qp) {
+bool CustomElement::parseCircle(QDomElement &e, QPainter &qp, bool addtolist) {
qreal cercle_x, cercle_y, cercle_r;
if (!QET::attributeIsAReal(e, QString("x"), &cercle_x)) return(false);
@@ -505,9 +510,11 @@
QRectF circle_bounding_rect(cercle_x, cercle_y, cercle_r, cercle_r);
- // Add circle to list
- QRectF *circle = new QRectF(circle_bounding_rect);
- m_circles << circle;
+ if (addtolist){
+ // Add circle to list
+ QRectF *circle = new QRectF(circle_bounding_rect);
+ m_circles << circle;
qp.drawEllipse(circle_bounding_rect);
qp.restore();
@@ -527,7 +534,7 @@
-bool CustomElement::parseEllipse(QDomElement &e, QPainter &qp) {
+bool CustomElement::parseEllipse(QDomElement &e, QPainter &qp, bool addtolist) {
qreal ellipse_x, ellipse_y, ellipse_l, ellipse_h;
if (!QET::attributeIsAReal(e, QString("x"), &ellipse_x)) return(false);
@@ -537,14 +544,16 @@
qp.save();
- QVector<qreal> *arc = new QVector<qreal>;
- arc -> push_back(ellipse_x);
- arc -> push_back(ellipse_y);
- arc -> push_back(ellipse_l);
- arc -> push_back(ellipse_h);
- arc -> push_back(0);
- arc -> push_back(360);
- m_arcs << arc;
+ if (addtolist){
+ QVector<qreal> *arc = new QVector<qreal>;
+ arc -> push_back(ellipse_x);
+ arc -> push_back(ellipse_y);
+ arc -> push_back(ellipse_l);
+ arc -> push_back(ellipse_h);
+ arc -> push_back(0);
+ arc -> push_back(360);
+ m_arcs << arc;
qp.drawEllipse(QRectF(ellipse_x, ellipse_y, ellipse_l, ellipse_h));
qp.restore();
@@ -565,7 +574,7 @@
-bool CustomElement::parseArc(QDomElement &e, QPainter &qp) {
+bool CustomElement::parseArc(QDomElement &e, QPainter &qp, bool addtolist) {
qreal arc_x, arc_y, arc_l, arc_h, arc_s, arc_a;
if (!QET::attributeIsAReal(e, QString("x"), &arc_x)) return(false);
@@ -578,14 +587,16 @@
qp.save();
- arc -> push_back(arc_x);
- arc -> push_back(arc_y);
- arc -> push_back(arc_l);
- arc -> push_back(arc_h);
- arc -> push_back(arc_s);
- arc -> push_back(arc_a);
- m_arcs << arc;
+ if (addtolist){
+ arc -> push_back(arc_x);
+ arc -> push_back(arc_y);
+ arc -> push_back(arc_l);
+ arc -> push_back(arc_h);
+ arc -> push_back(arc_s);
+ arc -> push_back(arc_a);
+ m_arcs << arc;
qp.drawArc(QRectF(arc_x, arc_y, arc_l, arc_h), (int)(arc_s * 16), (int)(arc_a * 16));
qp.restore();
@@ -603,7 +614,7 @@
-bool CustomElement::parsePolygon(QDomElement &e, QPainter &qp) {
+bool CustomElement::parsePolygon(QDomElement &e, QPainter &qp, bool addtolist) {
int i = 1;
while(true) {
if (QET::attributeIsAReal(e, QString("x%1").arg(i)) && QET::attributeIsAReal(e, QString("y%1").arg(i))) ++ i;
@@ -630,11 +641,12 @@
// insert first point at the end again for DXF export.
points.push_back(points[0]);
+ if (addtolist){
+ // Add to list of polygons.
+ QVector<QPointF> *poly = new QVector<QPointF>(points);
+ m_polygons << poly;
- // Add to list of polygons.
- QVector<QPointF> *poly = new QVector<QPointF>(points);
- m_polygons << poly;
qp.restore();
return(true);
@@ -648,7 +660,7 @@
-bool CustomElement::parseText(QDomElement &e, QPainter &qp) {
+bool CustomElement::parseText(QDomElement &e, QPainter &qp, bool addtolist) {
qreal pos_x, pos_y;
int size;
if (
@@ -672,17 +684,19 @@
text_document.setDefaultFont(used_font);
text_document.setPlainText(e.attribute("text"));
- //Add element to list of texts.
- ElementTextItem *eti = new ElementTextItem(e.attribute("text"));
- eti -> setFont(QETApp::diagramTextsFont(size));
- eti -> setOriginalPos(QPointF(pos_x, pos_y));
- eti -> setPos(pos_x, pos_y);
- qreal original_rotation_angle = 0.0;
- QET::attributeIsAReal(e, "rotation", &original_rotation_angle);
- eti -> setOriginalRotationAngle(original_rotation_angle);
- eti -> setRotationAngle(original_rotation_angle);
- eti -> setFollowParentRotations(e.attribute("rotate") == "true");
- m_texts << eti;
+ if (addtolist){
+ //Add element to list of texts.
+ ElementTextItem *eti = new ElementTextItem(e.attribute("text"));
+ eti -> setFont(QETApp::diagramTextsFont(size));
+ eti -> setOriginalPos(QPointF(pos_x, pos_y));
+ eti -> setPos(pos_x, pos_y);
+ qreal original_rotation_angle = 0.0;
+ QET::attributeIsAReal(e, "rotation", &original_rotation_angle);
+ eti -> setOriginalRotationAngle(original_rotation_angle);
+ eti -> setRotationAngle(original_rotation_angle);
+ eti -> setFollowParentRotations(e.attribute("rotate") == "true");
+ m_texts << eti;
// Se positionne aux coordonnees indiquees dans la description du texte
qp.setTransform(QTransform(), false);
Index: customelement.h
--- customelement.h (revision 5253)
+++ customelement.h (working copy)
@@ -80,14 +80,14 @@
protected:
virtual bool buildFromXml(const QDomElement &, int * = nullptr);
- virtual bool parseElement(QDomElement &, QPainter &);
- virtual bool parseLine(QDomElement &, QPainter &);
- virtual bool parseRect(QDomElement &, QPainter &);
- virtual bool parseEllipse(QDomElement &, QPainter &);
- virtual bool parseCircle(QDomElement &, QPainter &);
- virtual bool parseArc(QDomElement &, QPainter &);
- virtual bool parsePolygon(QDomElement &, QPainter &);
- virtual bool parseText(QDomElement &, QPainter &);
+ virtual bool parseElement(QDomElement &, QPainter &, bool addtolist = true);
+ virtual bool parseLine(QDomElement &, QPainter &, bool addtolist = true);
+ virtual bool parseRect(QDomElement &, QPainter &, bool addtolist = true);
+ virtual bool parseEllipse(QDomElement &, QPainter &, bool addtolist = true);
+ virtual bool parseCircle(QDomElement &, QPainter &, bool addtolist = true);
+ virtual bool parseArc(QDomElement &, QPainter &, bool addtolist = true);
+ virtual bool parsePolygon(QDomElement &, QPainter &, bool addtolist = true);
+ virtual bool parseText(QDomElement &, QPainter &, bool addtolist = true);
virtual bool parseInput(QDomElement &);
virtual DynamicElementTextItem *parseDynamicText(QDomElement &);
virtual Terminal *parseTerminal(QDomElement &);
by the way for me it seems low_zoom_drawing is useless as it seems for me that it never switch for that at me. maybe it works in other OS but not here
that options->levelOfDetail is always 1 at me if zoomed in or zoomed out |
This commit not fix it? Revision: 5250 Author: blacksun Date: 2018-03-01 19:45:40 +0100 (Thu, 01 Mar 2018) Log Message: ----------- Fix bug N°153 |
no, i added qetgraphicsitem.patch what fill fix that |
| 2018-02-06 16:30 | gabberworld | New Issue | |
| 2018-02-06 16:30 | gabberworld | File Added: exportdialog.cpp.patch | |
| 2018-02-06 20:28 | gabberworld | Note Added: 0000296 | |
| 2018-02-11 16:26 | gabberworld | File Added: dxf.color.patch | |
| 2018-02-11 16:26 | gabberworld | Note Added: 0000299 | |
| 2018-02-11 17:15 | scorpio810_mantis | Note Added: 0000300 | |
| 2018-03-01 07:58 | scorpio810_mantis | Status | new => resolved |
| 2018-03-01 07:58 | scorpio810_mantis | Resolution | open => fixed |
| 2018-03-01 07:58 | scorpio810_mantis | Fixed in Version | => SVN/trunk |
| 2018-03-01 10:01 | gabberworld | Status | resolved => feedback |
| 2018-03-01 10:01 | gabberworld | Resolution | fixed => reopened |
| 2018-03-01 10:01 | gabberworld | Note Added: 0000316 | |
| 2018-03-01 19:49 | black_sun | Assigned To | => black_sun_2012 |
| 2018-03-01 19:49 | black_sun | Status | feedback => resolved |
| 2018-03-01 20:15 | scorpio810_mantis | Note Added: 0000317 | |
| 2018-03-01 23:22 | gabberworld | Status | resolved => feedback |
| 2018-03-01 23:22 | gabberworld | Note Added: 0000318 | |
| 2018-03-01 23:25 | gabberworld | Note Added: 0000319 | |
| 2018-03-01 23:25 | gabberworld | Status | feedback => assigned |
| 2018-03-04 10:49 | gabberworld | File Added: qetgraphicsitem.patch | |
| 2018-03-04 10:49 | gabberworld | Note Added: 0000320 | |
| 2018-03-05 17:28 | gabberworld | Note Added: 0000321 | |
| 2018-03-08 19:23 | scorpio810_mantis | Note Added: 0000322 | |
| 2018-03-08 23:45 | gabberworld | Note Added: 0000323 | |
| 2021-02-15 00:48 |
