0000138 | QElectroTech | website | public | 2017-02-15 13:01 | 2021-02-15 00:50 |
Reporter | Ikkuh | Assigned To | |||
Priority | normal | Severity | major | Reproducibility | always |
Platform | windows | OS | 10 | OS Version | 10 |
Summary | 0000138: changing language does not work | ||||
Description | When I set the language to English and save, then restart the program it is still in French. | ||||
Steps To Reproduce | see above | ||||
Additional Information | version 0.5 | ||||
Attached Files | |||||
I now downloaded the 32bit zip and it works. So the problems are only in the 64bit version. Screenprint is of the 64bit version. |
oops, spoke too soon. I changed the language to Dutch and now everything is in French again. And it will not save the correct language anymore. |
I changed the .bat file to: set command=bin\qelectrotech.exe --common-elements-dir=elements/ --common-tbt-dir=titleblocks/ -- LANG=en_EN --lang-dir=lang/ --config-dir=conf/ %* So I added the --lang=en_EN and now qelectrotech is in English just like I wanted. |
Thank for report, but I just tried in Seven 64 bits VM and I don't find any problem. |
You use latest devel version? |
I use windows 10 and I have the problem I use this version: see qe_1.png picture, it is a release version I think. |
Ok, but you could try latest devel version? https://download.qelectrotech.org/qet/builds/nightly/2017-02-16-1/ |
oops, misunderstood you. Will give it a go tomorrow. btw: Thank you and all the others that work on this software, it is very nice to use it. It works better then expensive software like Designspark electrical, Trikker. Keep up the good work and thanks again! |
Thank you for compliments, and you haven't tried devel version yet |
2017-02-15 13:01 | Ikkuh | New Issue | |
2017-02-15 13:01 | Ikkuh | File Added: qe_2.png | |
2017-02-15 13:50 | Ikkuh | File Added: qe_1.png | |
2017-02-15 13:50 | Ikkuh | Note Added: 0000235 | |
2017-02-15 13:54 | Ikkuh | Note Added: 0000236 | |
2017-02-15 14:11 | Ikkuh | Note Added: 0000237 | |
2017-02-16 17:55 | scorpio810_mantis | Note Added: 0000238 | |
2017-02-16 18:07 | scorpio810_mantis | Note Added: 0000239 | |
2017-02-16 19:00 | Ikkuh | Note Added: 0000240 | |
2017-02-16 19:31 | scorpio810_mantis | Note Added: 0000241 | |
2017-02-16 19:32 | scorpio810_mantis | Note Edited: 0000241 | |
2017-02-16 19:38 | Ikkuh | Note Added: 0000242 | |
2017-02-16 19:52 | scorpio810_mantis | Note Added: 0000243 | |
2017-02-16 19:53 | scorpio810_mantis | Note Edited: 0000243 | |
2018-06-19 14:30 | scorpio810_mantis | Status | new => resolved |
2018-06-19 14:30 | scorpio810_mantis | Resolution | open => fixed |
2018-06-19 14:30 | scorpio810_mantis | Product Version | SVN/branches/0.x => SVN/trunk |
2021-01-08 15:03 | JanB | Relationship added | related to 0000222 |
2021-02-15 00:44 |
Product Version | SVN/trunk => 0.8 |
2021-02-15 00:45 |
2021-02-15 00:47 |
2021-02-15 00:50 |
