Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
en:doc:install_ubuntu [30/03/2018 14:33] – [PPA version 0.7-dev] scorpio810 | en:doc:install_ubuntu [04/01/2020 20:56] – scorpio810 | ||
Line 1: | Line 1: | ||
+ | ====== Installation of the QElectroTech development version on Ubuntu/Mint ====== | ||
+ | The stable versions of QElectroTech under Ubuntu : 0.4 for Wily, and 0.5 for Xenial are available directly from the official Ubuntu repositories (use the Software Center or Synaptic). | ||
+ | ===== PPA Ubuntu 0.60 version===== | ||
+ | This PPA provides 32 and 64 bits packages of the stable version for the distributions Xenial, Wily, Vivid and Trusty. | ||
+ | [[https:// | ||
+ | [[http:// | ||
+ | ==== Add the PPA repository ==== | ||
+ | The following entry assigns a high priority to all versions of the QElectroTech package beginning with 0.60. : \\ | ||
+ | This way, your system will download the higher package version from the ppa and not those from the official Ubuntu repositories. | ||
+ | Create manually the file 40qelectrotech-devel | ||
+ | Pin: version 0.60.* | ||
+ | Pin-Priority: | ||
+ | Then, update the cache of your system: < | ||
+ | That's it, QElectroTech should correctly be installed. Run it via the command “qelectrotech”. \\ If your desktop environment follows the FreeDesktop.org standards, QET \\ should also appear in its menus and the .qet and .elmt files should be opened by default by QElectroTech. | ||
+ | ===== PPA version 0.8-dev ===== | ||
+ | This PPA provides 32 and 64 bits packages of the current development version for the distributions Xenial, Artful. | ||
+ | https:// | ||
+ | Pinning upgrade (sed): | ||
+ | sudo sed -i ' | ||
