| doc:translation [25/01/2023 16:04] – [Comment tester sa traduction] scorpio810 | doc:translation [13/09/2026 08:46] (Version actuelle) – [New Qt6 version] scorpio810 |
| * le manuel Unix dans ''man/'' ; | * The ''CREDIT'', ''README'', ''ELEMENTS.LICENSE'', ''INSTALL'' files ; |
| * les fichiers ''CREDIT'', ''README'', ''ELEMENTS.LICENSE'', ''INSTALL'' ; | * The file ''packaging/linux/fedora/README.elements''. |
| * [[https://www.qt.io/offline-installers?hsLang=en]] | * [[https://www.qt.io/offline-installers?hsLang=en]] |
| * [[https://qelectrotech.org/forum/viewtopic.php?pid=16027#p16027|Qet_translate : Element translation tool]] [[https://download.tuxfamily.org/qet/builds/qet_translate/ |Download ]] | * [[https://qelectrotech.org/forum/viewtopic.php?pid=16027#p16027|Qet_translate : Element translation tool]] [[https://download.qelectrotech.org/qet/builds/qet_translate/ |Download ]] |
| ===== And after ? ===== | ===== And after ? ===== |
| * Maintenance of translations by regular monitoring of changes in the Git or Github repository; | * Maintenance of translations by regular monitoring of changes in the Git or Github repository; |
| </code> | </code> |
| Ou | |
| | <code> |
| | QT_QPA_PLATFORMTHEME=generic qelectrotech |
| | </code> |
| <code> | <code> |
| Download this script to put in your git copy | Download this script to put in your git copy |
| Make it executable | Make it executable |
| ===== How to update .ts files from source files? ===== | ===== How to update .ts files from source files? ===== |
| Note: *.ts are generally updated by the developer when he considers that the character strings to be translated are viable or by translators. | Note: *.ts are generally updated by the developer when he considers that the character strings to be translated are viable or by translators. |
| * Édit qelectrotech.pro : Comment out the lines starting with ''TRANSLATIONS += '' : <code bash>sed -i 's/^TRANSLATIONS/#TRANSLATIONS/g' qelectrotech.pro</code> | * Édit qelectrotech.pro file: Comment out the lines starting with ''TRANSLATIONS += '' : <code bash>sed -i 's/^TRANSLATIONS/#TRANSLATIONS/g' qelectrotech.pro</code> |
| * Run the following command :: <code>lupdate -noobsolete qelectrotech.pro -ts lang/qet_{en,es,ru,pt,cs,pl,ca,de,ro,it,ar,sl,hr,el,nl,be,sl,zh,hu,pt_br,da,sr,fr,tr,sk,nb,mn,ja,cn,uk}.ts</code> | * Run the following command: <code>lupdate -noobsolete qelectrotech.pro -ts lang/qet_{ar,ca,cs,da,de,el,en,es,fr,hr,hu,it,ja,ko,mn,nb,nl_BE,nl_NL,pl,pt,pt_BR,ro,rs,ru,sk,sl,sr,sv,tr,uk,zh}.ts</code> |
| * Restore missing references to source files : <code>/usr/lib/x86_64-linux-gnu/qt5/bin/lupdate -locations absolute qelectrotech.pro -ts lang/qet_br.ts</code> | * Restore missing references to source files : <code>/usr/lib/x86_64-linux-gnu/qt5/bin/lupdate -locations absolute qelectrotech.pro -ts lang/qet_br.ts</code> |
| * Restore file qelectrotech.pro : <code bash>sed -i 's/^#TRANSLATIONS/TRANSLATIONS/g' qelectrotech.pro</code> | * Restore file qelectrotech.pro: <code bash>sed -i 's/^#TRANSLATIONS/TRANSLATIONS/g' qelectrotech.pro</code> |
| * Create translations binary files : <code>lrelease lang/qet_*.ts</code> | * Generate translation binaries: <code>lrelease lang/qet_*.ts</code> |
| | ==== New Qt6 version ==== |
| | <code>/usr/lib/qt6/bin/lupdate -no-obsolete sources/ -ts lang/qet_*.ts</code> |
| | <code> |
| | cmake -B build |
| | cmake --build build --target update_translations |
| | </code> |
| | or |
| | <code> |
| | cd build |
| | cmake .. |
| | make update_translations |
| | </code> |
| | </code> |
| ===== translation status ===== | ===== translation status ===== |
