| doc:test_en [17/09/2013 14:12] – [3.1. Description Editor] scorpio810 | doc:test_en [20/11/2014 14:02] (Version actuelle) – modification externe 127.0.0.1 | ||
| Ligne 1: | Ligne 1: | ||
| + | {{ QuickStart_QET_pl_html_7ee93e7f.png? | ||
| + | ** Version 0.3 ** | ||
| + | ====== 1 Introduction ====== | ||
| + | ===== 1.1. QElectroTech ===== | ||
| + | - QElectroTech is an application for creating circuit diagrams . Editor has elements that can be used to create custom components. Creates a single line or multi-line system diagrams | ||
| + | electrical drawings for automation projects in different languages | ||
| + | - Programming , electronic circuit diagrams , and more. For saving schemes and elements used in an XML format . QElectroTech is free software released under the GNU / GPL version 2 , for the following systems: MS Windows , GNU / Linux and MacOS . | ||
| + | ===== 1.2. Installation ===== | ||
| + | - The latest version of QElectroTech can be downloaded from [[ http:// | ||
| + | ===== 1.3. Notes ===== | ||
| + | - Library of components supplied with QElectroTech , is in the form of " AS IS " without any warranties . Allowed to edit , modify and users elements without condition and regardless of the final license created schemas. In the case of the use of all or part of the component libraries QElectroTech for purposes other than the creation of electrical schematics , observe the terms of the license CC -BY : This work is licensed under a Creative Commons Attribution 3.0 license . To view a copy of the license, please visit our website: [[ http:// | ||
| + | ====== 2 Edit Schema ====== | ||
| + | ===== 2.1. Description Schema Editor ===== | ||
| + | \\ \\ {{QuickStart_QET_pl_html_97e07c97.png? | ||
| + | ** ** Main Toolbar - contains icons for basic functions of creating and editing diagrams. | ||
| + | Toolbar ** ** Elements panel - lets you create and edit categories and components. | ||
| + | ** List schemes and design elements ** - contains a list of all schemes included in the active project and used items in the project. | ||
| + | Collection of QElectroTech ** ** - a collection of components supplied with with the application. | ||
| + | Collection of user ** ** - a collection of connected components application by the user. | ||
| + | History of operations ** ** - tab which lists all made and withdrawn transactions. | ||
| + | Title Block ** ** - table which contains the basic data schema : title, author , date , file name , number and number of pages . | ||
| + | ===== 2.2. Create a new project ===== | ||
| + | - Choose from a menu // ** File → New → ** // or click | ||
| + | \\ {{ QuickStart_QET_pl_html_7b7e564c.png? | ||
| + | \\ {{ QuickStart_QET_pl_html_81308120.png? | ||
| + | ===== 2.3. Create new scheme ===== | ||
| + | - Create a new project is created scheme called ** " scheme with no name " ** , select from the menu // ** → Edit → Properties schema ** // or click | ||
| + | {{ QuickStart_QET_pl_html_910d67d1.png? | ||
| + | ===== 2.4. Inserting elements ===== | ||
| + | - Left-click on the selected item from the collection , then drag it and drop the release button in the editing of schedules . In the next step, click on the inserted item by dragging it with the left mouse button and rotate it to the desired position using the menu // ** → Edit → Rotate ** // or click | ||
| + | \\ - {{QuickStart_QET_pl_html_58eaadbd.png? | ||
| + | ===== 2.5. Text boxes ===== | ||
| + | Type designation of the item in the box. | ||
| + | \\ {{ QuickStart_QET_pl_html_54f5c383.png? | ||
| + | text field level despite trading item poleobróci together | ||
| + | with the item. Select from the menu // ** → Edit → Text Orientation ** // and select the angle of rotation | ||
| + | text relative to the open window . | ||
| + | \\ {{ QuickStart_QET_pl_html_a4360fa0.gif }} {{ QuickStart_QET_pl_html_f3219c73.png? | ||
| + | \\ After selecting the desired angle can change the position of the text box | ||
| + | relative to the element. To do this, select the text box , the | ||
| + | a decorated piece with the mouse and drag the field to the right | ||
| + | place . Offset relative to the field is indicated by shading | ||
| + | the item in the color blue. Position the text box depends | ||
| + | the position of the element, the element moves the shift field | ||
| + | text . | ||
| + | \\ {{ QuickStart_QET_pl_html_360acf94.png? | ||
| + | ===== 2.6. Insert wires ===== | ||
| + | - To insert the cable , place the mouse cursor over the point capture the element that you want to connect. Then when you see the flag in blue, press the left mouse button and move the cursor over the point capture the element you want to call , after the appearance of the marker in green or orange , release the mouse button. | ||
| + | \\ {{ QuickStart_QET_pl_html_e6524446.gif }} {{ QuickStart_QET_pl_html_ca93f543.png? | ||
| + | orange appears when the element is no longer calls made earlier. | ||
| + | Red indicates that the link is not allowed. If the | ||
| + | Cable properties is selected multi-line ** ** field appears | ||
| + | Text to enter the cable markings , with this option selected | ||
| + | Single- ** ** A visual indication of the number and type of cable . In the event | ||
| + | need to change the cable route , check the cord dragging over it | ||
| + | the mouse with the left button , the wire turns | ||
| + | red and green handles will appear , which you can use to change route | ||
| + | wires. | ||
| + | \\ {{ QuickStart_QET_pl_html_92ff2ed8.gif }} {{ QuickStart_QET_pl_html_ca8c20ce.gif }} {{ QuickStart_QET_pl_html_9eb9187c.gif }} {{ QuickStart_QET_pl_html_97e15fd3.png? | ||
| + | // ** Edit → Restore route cables ** // , or click the icon | ||
| + | ===== 3.1. Description Editor ===== | ||
| + | elements | ||
| + | {{ QuickStart_QET_pl_html_61d9af01.png? | ||
| + | **Main Toolbar** - contains icons for basic functions the creation and editing of elements. | ||
| + | **Drawing toolbar** | ||
| + | line, rectangle , ellipse, circle , polygon , arc , text , text box , and point Rapture . | ||
| + | **Active Area** - an area that is edited item . | ||
| + | **Information about lots** - displays the selected options of the graphic edited feature . | ||
| + | **List the item**- list of all the graphics included in the element. | ||
| + | **History of operations** - tab which lists all made and withdrawn transactions. | ||
| + | ===== 3.2. Creating a new element ===== | ||
| + | In the Contents pane , right-click on the collection of user | ||
| + | and select from the popup menu // ** → New Category ** // or press the icon | ||
| + | \\ {{ QuickStart_QET_pl_html_f0d62e4b.png? | ||
| + | ** row ** , you can enter the name in other languages. | ||
| + | \\ {{ QuickStart_QET_pl_html_4ee6886d.png? | ||
| + | Then right-click on the collection of user | ||
| + | and select from the popup menu // ** → New Item ** // , or click the icon | ||
| + | \\ {{ QuickStart_QET_pl_html_14b42e4b.png? | ||
| + | for an item , the file name, the name of the item , size and active area and | ||
| + | orientation . Then click the icon editor elements | ||
| + | {{ QuickStart_QET_pl_html_2dbdc77.png? | ||
| + | separated by 20 points. | ||
| + | \\ {{ QuickStart_QET_pl_html_bf1ef4d.png? | ||
| + | The information is displayed options that part. Then click the icon | ||
| + | \\ {{ QuickStart_QET_pl_html_bd611772.png? | ||
| + | horizontal diameter : 5, vertical diameter of 5 , the start angle 0 and angle : 180 then | ||
| + | arc ready to drag the vertical line as shown. | ||
| + | \\ {{ QuickStart_QET_pl_html_73d3d90c.png? | ||
| + | lines. | ||
| + | {{ QuickStart_QET_pl_html_edc63b8e.gif }} {{ QuickStart_QET_pl_html_256ffa1e.png? | ||
| + | \\ {{ QuickStart_QET_pl_html_f334c58f.png? | ||
| + | Information on the orientation of the capture points north and south , respectively | ||
| + | to the destination. Orientation capture points indicates the direction | ||
| + | the attachment of the element. Capture points are red , | ||
| + | marked change color to blue. | ||
| + | \\ \\ {{ QuickStart_QET_pl_html_e778a474.png? | ||
| + | \\ {{ QuickStart_QET_pl_html_1b3465bb.png? | ||
| + | when you insert it into the diagram . The text box is different from the text that can be | ||
| + | edited after inserting an item into the schematic editor and can maintain | ||
| + | vertical position despite the rotation of the schema editor . text Size | ||
| + | Default character and the other options we set in the Information pane when you select text | ||
| + | or text box. | ||
| + | \\ {{ QuickStart_QET_pl_html_f3968b0c.png? | ||
| + | select from menu // ** → Edit → Edit size and active area ** // or click | ||
| + | icon | ||
| + | \\ {{ QuickStart_QET_pl_html_ebb3473d.png? | ||
| + | area is marked in purple. | ||
| + | \ \ {{ QuickStart_QET_pl_html_4a638f4b.png? | ||
| + | \\ {{ QuickStart_QET_pl_html_f39cb55c.png? | ||
| + | After selecting the menu // ** → Edit → Edit orientation ** // or click the icon | ||
| + | \\ {{ QuickStart_QET_pl_html_ce82cf1e.png? | ||
| + | Additionally, | ||
| + | Select from the menu ** → Edit → 's Information ** or by clicking | ||
| + | \\ {{ QuickStart_QET_pl_html_144612ee.png? | ||
| + | refresh the collection by clicking on the icon | ||
| + | {{ QuickStart_QET_pl_html_9975aa38.png? | ||
| + | ====== 4 Printing patterns ====== | ||
| + | \\ ===== 4.1. Select the type of print ===== | ||
| + | - To print the chart , select from the menu // ** → File → Print ** // or click on the icon , | ||
| + | \\ {{ QuickStart_QET_pl_html_336602f1.png? | ||
| + | \\ {{ QuickStart_QET_pl_html_1c309c13.png? | ||
| + | ===== 4.2. Print Preview ===== | ||
| + | \\ \\ {{ QuickStart_QET_pl_html_b54e6938.png? | ||
| + | and hiding the print options , and changes in the preview schemas. | ||
| + | Design patterns ** List ** - You can select and deselect schemes | ||
| + | print . | ||
| + | Rendering ** ** Options - options for changing the appearance of the printed pattern. | ||
| + | Print Options ** ** - options for changing the print to fit the page. | ||
| + | \\ ====== 5 Export Schema ====== | ||
| + | QElectroTech can export diagrams to image files , such as: | ||
| + | PNG ** ** % % ( * % %. Png ) ** JPEG ** % % ( * % %. Jpg ) bitmap ** ** % % ( * % %. Bmp) ** SVG ** % % ( * % %. svg ) . | ||
| + | Select from the menu // ** File → Export → ** // and then in the window that opens, select | ||
| + | file type to which you want to export the diagram , select the destination folder | ||
| + | set other options and press ** Export ** . | ||
| + | \\ {{ QuickStart_QET_pl_html_df59257c.png? | ||
