doc:packaging_debian [21/07/2023 12:25] – Use HTTPS for download.qelectrotech.org xavierdoc:packaging_debian [17/01/2024 16:36] (Version actuelle) scorpio810
Ligne 258: Ligne 258:
 echo -e "\033[1;31mrsync to TF password ssh and TF\033[m" echo -e "\033[1;31mrsync to TF password ssh and TF\033[m"
 cd $DEFAULT_DIR/script cd $DEFAULT_DIR/script
-rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/debian/ +rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ server:download.qelectrotech.org/qet/qet-repository/debian/
 if [ $? != 0 ]; then if [ $? != 0 ]; then
 echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD "
-rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/debian/+rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ server:download.qelectrotech.org/qet/qet-repository/debian/
 } fi } fi
Ligne 533: Ligne 533:
 read a read a
 if [[ $a == "Y" || $a == "y" ]]; then if [[ $a == "Y" || $a == "y" ]]; then
-rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress  /home/laurent/builds/nightly/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/builds/nightly/ +rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress  /home/laurent/builds/nightly/ server:download.qelectrotech.org/qet/qet-repository/builds/nightly/
 } fi } fi
Ligne 557: Ligne 557:
 === AppImage === === AppImage ===
 +See:
 +We only use __01-build-host.sh__  script__ to build MacOS Macports environment for QET builds.
 +cd digikam/project/bundles/appimage</code>
 +<code=diff>
 +                   -release
 ++                  -system-sqlite                      # We use Sqlite3-dev deb package
 +                   -icu
 +-fi
 +-    fi
 +-    for ITEM in $DIRS ; do
 +-        cd $SUBDIR
 +-        cd $ORIG_WD
 +-    done
 +-    cat $KF6_GITREV_LST
 +-fi
 + TerminateScript
 + tinami.kde.org \
 +-fi
 +-    echo "Register $server"
 +-    ssh-keygen -R $server
 +-done
 + DK_DEBUG=0
 +-DK_QTWEBENGINE=1
 ++DK_QTWEBENGINE=0
 + #DK_SUBVER="-01"
 + DK_SIGN=0
 +-DK_UPLOAD=1
 ++DK_UPLOAD=0
 + done
 +-sudo apt-get install nodejs
 <code=bash> <code=bash>
Ligne 667: Ligne 863:
 flatpak-builder --force-clean --ccache --repo=qet_git/0.8-dev qet_git/build-dir qet_git/build-aux/flatpak/org.qelectrotech.QElectroTech.json --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX   --gpg-homedir=gpg flatpak-builder --force-clean --ccache --repo=qet_git/0.8-dev qet_git/build-dir qet_git/build-aux/flatpak/org.qelectrotech.QElectroTech.json --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX   --gpg-homedir=gpg
 flatpak build-update-repo qet_git/0.8-dev --title="Development builds of QElectroTech" --prune --prune-depth=4  --generate-static-deltas --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX   --gpg-homedir=gpg flatpak build-update-repo qet_git/0.8-dev --title="Development builds of QElectroTech" --prune --prune-depth=4  --generate-static-deltas --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX   --gpg-homedir=gpg
-rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress qet_git/0.8-dev/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/builds/Flatpak/+rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress qet_git/0.8-dev/ server:download.qelectrotech.org/qet/qet-repository/builds/Flatpak/
 </code> </code>
