doc:packaging_debian [14/02/2020 15:08] scorpio810doc:packaging_debian [17/01/2024 16:36] (Version actuelle) scorpio810
Ligne 16: Ligne 16:
    deb-src​ http://​debian.qelectrotech.org/​qet/​debian/​ stable main    deb-src​ http://​debian.qelectrotech.org/​qet/​debian/​ stable main
-[[http://download.tuxfamily.org/qet/debian/]]+[[https://download.qelectrotech.org/qet/debian/]]
 === Git Debian package ==== === Git Debian package ====
Ligne 258: Ligne 258:
 echo -e "\033[1;31mrsync to TF password ssh and TF\033[m" echo -e "\033[1;31mrsync to TF password ssh and TF\033[m"
 cd $DEFAULT_DIR/script cd $DEFAULT_DIR/script
-rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/debian/ +rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ server:download.qelectrotech.org/qet/qet-repository/debian/
 if [ $? != 0 ]; then if [ $? != 0 ]; then
 echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD "
-rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/debian/+rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ server:download.qelectrotech.org/qet/qet-repository/debian/
 } fi } fi
Ligne 533: Ligne 533:
 read a read a
 if [[ $a == "Y" || $a == "y" ]]; then if [[ $a == "Y" || $a == "y" ]]; then
-rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress  /home/laurent/builds/nightly/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/builds/nightly/ +rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress  /home/laurent/builds/nightly/ server:download.qelectrotech.org/qet/qet-repository/builds/nightly/
 } fi } fi
Ligne 557: Ligne 557:
 === AppImage === === AppImage ===
 +See:
 +We only use __01-build-host.sh__  script__ to build MacOS Macports environment for QET builds.
 +cd digikam/project/bundles/appimage</code>
 +<code=diff>
 +                   -release
 ++                  -system-sqlite                      # We use Sqlite3-dev deb package
 +                   -icu
 +-fi
 +-    fi
 +-    for ITEM in $DIRS ; do
 +-        cd $SUBDIR
 +-        cd $ORIG_WD
 +-    done
 +-    cat $KF6_GITREV_LST
 +-fi
 + TerminateScript
 + tinami.kde.org \
 +-fi
 +-    echo "Register $server"
 +-    ssh-keygen -R $server
 +-done
 + DK_DEBUG=0
 +-DK_QTWEBENGINE=1
 ++DK_QTWEBENGINE=0
 + #DK_SUBVER="-01"
 + DK_SIGN=0
 +-DK_UPLOAD=1
 ++DK_UPLOAD=0
 + done
 +-sudo apt-get install nodejs
 <code=bash> <code=bash>
 #!/bin/bash  #!/bin/bash
-#nettoyage des chroots +#set -x
-set -x+
 #delete old qet.h #delete old qet.h
 rm sources/qet.h rm sources/qet.h
-# Fait une mise à jour
-git pull
 cd sources cd sources
Ligne 575: Ligne 766:
 cd .. cd ..
 +git pull
 +sed -i 's/DEFINES += QET_EXPORT_PROJECT_DB/#DEFINES += QET_EXPORT_PROJECT_DB/' qelectrotech.pro
 GITCOMMIT=$(git rev-parse --short HEAD) GITCOMMIT=$(git rev-parse --short HEAD)
Ligne 581: Ligne 773:
 HEAD=$(($A+473)) HEAD=$(($A+473))
-VERSION=$(cat sources/qet.h | grep "const QString version" |  cut -d\" -f2 | cut -d\" -f1)          #Find version tag in Subversion sources/qet.h +VERSION=$(cat sources/qet.h | grep "const QString version" |  cut -d\" -f2 | cut -d\" -f1)          #Find version tag in GIT sources/qet.h
-tagName=$(cat sources/qet.h | grep displayedVersion |  cut -d\" -f2 | cut -d\" -f1)                 #Find displayedVersion tag in Subversion sources/qet.h+tagName=$(cat sources/qet.h | grep displayedVersion |  cut -d\" -f2 | cut -d\" -f1)                 #Find displayedVersion tag in GIT sources/qet.h
Ligne 592: Ligne 784:
-# On modifie l'originale avec le numero de revision du depot svn+# On modifie l'originale avec le numéro de révision du dépôt GIT
 sed -i 's/'"const QString displayedVersion =.*/const QString displayedVersion = \"$tagName+$GITCOMMIT\";"'/' sources/qet.h sed -i 's/'"const QString displayedVersion =.*/const QString displayedVersion = \"$tagName+$GITCOMMIT\";"'/' sources/qet.h
Ligne 601: Ligne 793:
 qmake ../qelectrotech.pro qmake ../qelectrotech.pro
-make -j16+make -j48
Ligne 627: Ligne 819:
 </code> </code>
 +=== Flatpak ===
 +<code=bash>
 +#!/bin/bash
 +#set -x
 +#delete old qet.h
 +rm sources/qet.h
 +cd sources
 +git reset --hard origin/master
 +cd ..
 +# Fait une mise à jour
 +git pull
 +#git checkout test_pugi
 +GITCOMMIT=$(git rev-parse --short HEAD)
 +A=$(git rev-list HEAD --count)
 +HEAD=$(($A+473))
 +VERSION=$(cat sources/qet.h | grep "const QString version" cut -d\" -f2 | cut -d\" -f1)          #Find version tag in GIT sources/qet.h
 +# recupere le numero de la nouvelle revision
 +#revAp=$(svnversion | cut -d : -f 2 | tr -d '[:alpha:]'
 +# On recupere le numero de version de l'originale
 +tagName=$(sed -n "s/const QString displayedVersion =\(.*\)/\1/p" sources/qet.h  | cut -d\" -f2 | cut -d\" -f1 )
 +# On modifie l'originale avec le numero de revision du depot svn
 +sed -i 's/'"const QString displayedVersion =.*/const QString displayedVersion = \"$tagName+$GITCOMMIT\";"'/' sources/qet.h
 +cd ~
 +flatpak-builder --force-clean --ccache --repo=qet_git/0.8-dev qet_git/build-dir qet_git/build-aux/flatpak/org.qelectrotech.QElectroTech.json --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX   --gpg-homedir=gpg
 +flatpak build-update-repo qet_git/0.8-dev --title="Development builds of QElectroTech" --prune --prune-depth=4  --generate-static-deltas --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX   --gpg-homedir=gpg
 +rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress qet_git/0.8-dev/ server:download.qelectrotech.org/qet/qet-repository/builds/Flatpak/
