doc:packaging_debian [21/07/2023 12:25] – Use HTTPS for download.qelectrotech.org xavier | doc:packaging_debian [17/01/2024 16:12] – scorpio810 | ||
Ligne 258: | Ligne 258: | ||
echo -e " | echo -e " | ||
cd $DEFAULT_DIR/ | cd $DEFAULT_DIR/ | ||
- | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/ | + | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/ |
if [ $? != 0 ]; then | if [ $? != 0 ]; then | ||
echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " | echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " | ||
} fi | } fi | ||
Ligne 533: | Ligne 533: | ||
read a | read a | ||
if [[ $a == " | if [[ $a == " | ||
- | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress | + | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress |
} fi | } fi | ||
Ligne 557: | Ligne 557: | ||
=== AppImage === | === AppImage === | ||
+ | See: | ||
+ | https:// | ||
+ | https:// | ||
+ | We only use __01-build-host.sh__ | ||
+ | git clone https:// | ||
+ | cd digikam/ | ||
+ | diff --git a/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | - -sql-sqlite | ||
+ | + -system-sqlite | ||
+ | -icu | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -fi | ||
+ | rm -fr / | ||
+ | rm -fr / | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | - fi | ||
+ | - cd $SUBDIR | ||
+ | - echo " | ||
+ | - cd $ORIG_WD | ||
+ | - done | ||
+ | -fi | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -if [[ ! -f $HOME/ | ||
+ | - touch $HOME/ | ||
+ | -fi | ||
+ | - echo " | ||
+ | -done | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -DK_QTWEBENGINE=1 | ||
+ | +DK_QTWEBENGINE=0 | ||
+ | -DK_UPLOAD=1 | ||
+ | +DK_UPLOAD=0 | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | echo " | ||
+ | done | ||
+ | -# https:// | ||
+ | -curl -sL https:// | ||
+ | echo -e " | ||
Ligne 667: | Ligne 863: | ||
flatpak-builder --force-clean --ccache --repo=qet_git/ | flatpak-builder --force-clean --ccache --repo=qet_git/ | ||
flatpak build-update-repo qet_git/ | flatpak build-update-repo qet_git/ | ||
- | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress qet_git/ | + | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress qet_git/ |
