doc:packaging_debian [08/10/2019 11:29] – scorpio810 | doc:packaging_debian [11/01/2024 15:59] – [Notes] scorpio810 | ||
Ligne 16: | Ligne 16: | ||
- | [[http:// | + | [[https:// |
=== Git Debian package ==== | === Git Debian package ==== | ||
Ligne 48: | Ligne 48: | ||
cd qet_git | cd qet_git | ||
git pull | git pull | ||
- | #git checkout | + | #git checkout |
GITCOMMIT=$(git rev-parse --short HEAD) | GITCOMMIT=$(git rev-parse --short HEAD) | ||
Ligne 258: | Ligne 258: | ||
echo -e " | echo -e " | ||
cd $DEFAULT_DIR/ | cd $DEFAULT_DIR/ | ||
- | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/ | + | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/ |
if [ $? != 0 ]; then | if [ $? != 0 ]; then | ||
echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " | echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " | ||
} fi | } fi | ||
Ligne 297: | Ligne 297: | ||
debuild -S -sa -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 | debuild -S -sa -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 | ||
- | #dch -i -D cosmic | + | dch -i -D eoan "Eoan Upload to ppa" |
- | #debuild -S -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 | + | debuild -S -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 |
Ligne 312: | Ligne 312: | ||
dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu1_source.changes | dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu1_source.changes | ||
dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu2_source.changes | dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu2_source.changes | ||
- | #dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu3_source.changes | + | dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu3_source.changes |
#dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu4_source.changes | #dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu4_source.changes | ||
Ligne 337: | Ligne 337: | ||
cd $DEFAULT_DIR | cd $DEFAULT_DIR | ||
- | cd qelectrotech-$VERSION.r$HEAD/ | + | cd qelectrotech-$VERSION.r$HEAD/ |
cp {lang_extra.nsh, | cp {lang_extra.nsh, | ||
Ligne 351: | Ligne 351: | ||
Ligne 362: | Ligne 362: | ||
- | export PATH=/ | + | export PATH=/ |
Ligne 370: | Ligne 370: | ||
#build jobs=17 | #build jobs=17 | ||
Ligne 377: | Ligne 377: | ||
#copy 32 bits binarie to /bin Windows packages | #copy 32 bits binarie to /bin Windows packages | ||
- | cd $DEFAULT_DIR/ | + | cd $DEFAULT_DIR/ |
cp qelectrotech.exe / | cp qelectrotech.exe / | ||
Ligne 395: | Ligne 395: | ||
+ | #export PATH=/ | ||
Ligne 403: | Ligne 404: | ||
#mxe: qmake-qt5 x86_64-w64 | #mxe: qmake-qt5 x86_64-w64 | ||
#make -j17 | #make -j17 | ||
make -j$(nproc) | make -j$(nproc) | ||
mv qelectrotech.exe / | mv qelectrotech.exe / | ||
Ligne 434: | Ligne 436: | ||
#cd $DEFAULT_DIR | #cd $DEFAULT_DIR | ||
- | #cd qelectrotech-$VERSION.r$HEAD/ | + | #cd qelectrotech-$VERSION.r$HEAD/ |
#cp {lang_extra.nsh, | #cp {lang_extra.nsh, | ||
Ligne 531: | Ligne 533: | ||
read a | read a | ||
if [[ $a == " | if [[ $a == " | ||
- | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress | + | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress |
} fi | } fi | ||
Ligne 549: | Ligne 551: | ||
fi | fi | ||
exit | exit | ||
Ligne 556: | Ligne 557: | ||
=== AppImage === | === AppImage === | ||
+ | See: | ||
+ | https:// | ||
+ | https:// | ||
+ | We only use __01-build-host.sh__ | ||
+ | git clone https:// | ||
+ | cd digikam/ | ||
+ | diff --git a/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | - -sql-sqlite | ||
+ | + -system-sqlite | ||
+ | -icu | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -fi | ||
+ | rm -fr / | ||
+ | rm -fr / | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | - fi | ||
+ | - cd $SUBDIR | ||
+ | - echo " | ||
+ | - cd $ORIG_WD | ||
+ | - done | ||
+ | -fi | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -if [[ ! -f $HOME/ | ||
+ | - touch $HOME/ | ||
+ | -fi | ||
+ | - echo " | ||
+ | -done | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -DK_QTWEBENGINE=1 | ||
+ | +DK_QTWEBENGINE=0 | ||
+ | -DK_UPLOAD=1 | ||
+ | +DK_UPLOAD=0 | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | echo " | ||
+ | done | ||
+ | -# https:// | ||
+ | -curl -sL https:// | ||
+ | echo -e " | ||
+ | @@ -231,8 +227,8 @@ echo -e " | ||
+ | # https:// | ||
+ | sudo add-apt-repository -y ppa: | ||
+ | -sudo apt install -y gcc-11 | ||
+ | -sudo apt install -y g++-11 | ||
+ | -sudo update-alternatives --install / | ||
+ | +sudo apt install -y gcc-13 | ||
+ | +sudo apt install -y g++-13 | ||
+ | +sudo update-alternatives --install / | ||
- | #nettoyage des chroots | + | #set -x |
- | set -x | + | |
#delete old qet.h | #delete old qet.h | ||
rm sources/ | rm sources/ | ||
- | # Fait une mise à jour | ||
- | git pull | ||
cd sources | cd sources | ||
Ligne 574: | Ligne 779: | ||
cd .. | cd .. | ||
+ | git pull | ||
+ | sed -i ' | ||
Ligne 580: | Ligne 786: | ||
HEAD=$(($A+473)) | HEAD=$(($A+473)) | ||
- | VERSION=$(cat sources/ | + | VERSION=$(cat sources/ |
- | tagName=$(cat sources/ | + | tagName=$(cat sources/ |
Ligne 591: | Ligne 797: | ||
- | # On modifie l' | + | # On modifie l' |
sed -i ' | sed -i ' | ||
Ligne 600: | Ligne 806: | ||
qmake ../ | qmake ../ | ||
- | make -j16 | + | make -j48 |
Ligne 626: | Ligne 832: | ||
+ | === Flatpak === | ||
+ | #!/bin/bash | ||
+ | #set -x | ||
+ | #delete old qet.h | ||
+ | rm sources/ | ||
+ | cd sources | ||
+ | cd .. | ||
+ | git pull | ||
+ | sed -i ' | ||
+ | HEAD=$(($A+473)) | ||
+ | tagName=$(sed -n " | ||
+ | # On modifie l' | ||
+ | sed -i ' | ||
+ | cd ~ | ||
