doc:packaging_debian [10/08/2018 05:24] – ancienne révision (10/08/2018 02:04) restaurée scorpio810 | doc:packaging_debian [08/10/2019 11:29] – scorpio810 | ||
+ | ~~NOCACHE~~ | ||
+ | ====== Notes ====== | ||
+ | #for Debian stable | ||
+ | deb http:// | ||
+ | [[http:// | ||
+ | [[http:// | ||
+ | #set -x | ||
+ | DEFAULT_DIR=" | ||
+ | TEMP_DIR=" | ||
+ | SSH_TARGET=' | ||
+ | SSH_OPTIONS=-B | ||
+ | #if [ -z " | ||
+ | #fi | ||
+ | cd $DEFAULT_DIR | ||
+ | cd qet_git | ||
+ | git pull | ||
+ | #git checkout foliolist_position | ||
+ | if [ -z " | ||
+ | HEAD=$(($A+473)) | ||
+ | fi | ||
+ | #95d1fca171 | ||
+ | #5475 | ||
+ | #clean / | ||
+ | echo -e " | ||
+ | read a | ||
+ | if [[ $a == " | ||
+ | echo -e " | ||
+ | cd / | ||
+ | cd / | ||
+ | cd / | ||
+ | cd / | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | #clean all apt cache | ||
+ | echo -e " | ||
+ | read a | ||
+ | echo -e " | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | #Update des chroots | ||
+ | echo -e " | ||
+ | read a | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | echo -e " | ||
+ | cd $TEMP_DIR | ||
+ | # svn export svn:// | ||
+ | #svn export svn:// | ||
+ | cp -r $DEFAULT_DIR/ | ||
+ | #create svn tarball | ||
+ | clean $TEMP_DIR | ||
+ | #clean debian folder | ||
+ | cd / | ||
+ | rm -Rf debian/ | ||
+ | #copy debian folder | ||
+ | #edit changelog | ||
+ | echo -e " | ||
+ | read a | ||
+ | dch --edit | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | cd $DEFAULT_DIR/ | ||
+ | sed -i ' | ||
+ | quilt push | ||
+ | quilt push | ||
+ | quilt refresh | ||
+ | echo -e " | ||
+ | read a | ||
+ | echo -e " | ||
+ | dch -i -D stable | ||
+ | STRING=" | ||
+ | echo $STRING | ||
+ | #save debian/ | ||
+ | #echo -e " | ||
+ | mkdir -p $HEAD/ | ||
+ | find / | ||
+ | find / | ||
+ | find / | ||
+ | find / | ||
+ | #debsign | ||
+ | echo -e " | ||
+ | read a | ||
+ | echo -e " | ||
+ | #debsign sid amd64 | ||
+ | echo -e " | ||
+ | #debsign stable i386 | ||
+ | echo -e " | ||
+ | #debsign sid i386 | ||
+ | echo -e " | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | echo -e " | ||
+ | read a | ||
+ | echo -e " | ||
+ | cd ~/apt | ||
+ | #rm db/* | ||
+ | reprepro -b . export | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | #rsync to TF | ||
+ | echo -e " | ||
+ | read a | ||
+ | echo -e " | ||
+ | echo -e " | ||
+ | rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ scorpio810@ssh.tuxfamily.org:/ | ||
+ | if [ $? != 0 ]; then | ||
+ | } fi | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | echo -e " | ||
+ | read a | ||
+ | #dch -i -D yakkety " | ||
+ | #dch -i -D xenial " | ||
+ | #dch -i -D artful " | ||
+ | dch -i -D bionic " | ||
+ | #dch -i -D cosmic " | ||
+ | #dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu3_source.changes | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | echo -e " | ||
+ | read a | ||
+ | # 32 bits | ||
+ | cp -r {elements, | ||
+ | cp -r lang/ | ||
+ | cp {lang_extra.nsh, | ||
+ | # 64 bits | ||
+ | export PATH=/ | ||
+ | #build jobs=17 | ||
+ | #make -j17 | ||
+ | make -j$(nproc) | ||
+ | #cd $DEFAULT_DIR/ | ||
+ | sed -i ' | ||
+ | makensis QET.nsi | ||
+ | rm -r build/ | ||
+ | #make -j17 | ||
+ | sed -i ' | ||
+ | makensis QET64.nsi | ||
+ | # WIN XP VISTA build | ||
+ | #cd $DEFAULT_DIR | ||
+ | #cp -r {elements, | ||
+ | #cp -r lang/ | ||
+ | #cp {lang_extra.nsh, | ||
+ | #cd /home/$USER | ||
+ | #mv mxe mxe_old | ||
+ | #mv mxeXP mxe | ||
+ | #sleep 4 | ||
+ | #make -j17 | ||
+ | #make -j$(nproc) | ||
+ | #mv mxe mxeXP | ||
+ | #mv mxe_old mxe | ||
+ | #sed -i ' | ||
+ | #makensis QET.nsi | ||
+ | echo -e " | ||
+ | read a | ||
+ | cd / | ||
+ | i=1 | ||
+ | while [ "$(ls / | ||
+ | ((i++)) | ||
+ | done | ||
+ | mkdir / | ||
+ | #mkdir / | ||
+ | cd / | ||
+ | #cd / | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | echo -e " | ||
+ | read a | ||
+ | } fi | ||
+ | #cd ~/ | ||
+ | #sed -i ' | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | else | ||
+ | echo -e " | ||
+ | fi | ||
+ | exit | ||
+ | === AppImage === | ||
+ | set -x | ||
+ | #delete old qet.h | ||
+ | rm sources/ | ||
+ | git pull | ||
+ | cd sources | ||
+ | cd .. | ||
+ | tagName=$(sed -n " | ||
+ | # On modifie l' | ||
+ | sed -i ' | ||
+ | rm -Rf build/ | ||
+ | qmake ../ | ||
+ | make -j16 | ||
+ | cd ../appdir/ | ||
+ | rm qelectrotech/ | ||
+ | rm -Rf qelectrotech/ | ||
+ | cp ../ | ||
+ | cp -r ../ | ||
+ | sed -i ' | ||
+ | ARCH=x86_64 ./ | ||
