doc:macosx [17/01/2023 22:24] – [MacOS Macports environment (new 2023)] scorpio810doc:macosx [09/01/2024 16:01] (Version actuelle) – [Macports arm64 Apple silicon environments MAC Mini M2] scorpio810
 ~~NOCACHE~~ ~~NOCACHE~~
-====== QElectroTech sous MacOSX ======+===== QElectroTech sous MacOSX =====
 +===== Macports arm64 Apple silicon environments MAC Mini M2 =====
 +cd digikam/project/bundles/macports/
 +<code=diff>diff --git a/project/bundles/3rdparty/ext_kf5/CMakeLists.txt b/project/bundles/3rdparty/ext_kf5/CMakeLists.txt
 +index 41a75f247f..04307322bd 100755
 +--- a/project/bundles/3rdparty/ext_kf5/CMakeLists.txt
 ++++ b/project/bundles/3rdparty/ext_kf5/CMakeLists.txt
 +@@ -107,7 +107,7 @@ function(InstallKDEComponent
 +                             CONFIGURE_COMMAND cp ${CMAKE_CURRENT_SOURCE_DIR}/../../../../bootstrap.macports <SOURCE_DIR>/. &&
 +                                               sed -i '' -e "s/DBUILD_TESTING=ON/DBUILD_TESTING=OFF/g" <SOURCE_DIR>/bootstrap.macports &&
 +-                                              <SOURCE_DIR>/bootstrap.macports ${EXTPREFIX_frameworks} debug x86_64 "${argoptions}"
 ++                                              <SOURCE_DIR>/bootstrap.macports ${EXTPREFIX_frameworks} debug arm64 "${argoptions}"
 +                             BUILD_COMMAND cd <SOURCE_DIR>/build && $(MAKE)
 +diff --git a/project/bundles/macports/01-build-macports.sh b/project/bundles/macports/01-build-macports.sh
 +index 669ec675c1..82ac0ff093 100755
 +--- a/project/bundles/macports/01-build-macports.sh
 ++++ b/project/bundles/macports/01-build-macports.sh
 +@@ -210,7 +210,7 @@ EOF
 +         # No need to build with both architectures embeded (x86 and ARM) for Apple Silicon target
 +         cat << EOF >> "$INSTALL_PREFIX/etc/macports/variants.conf"
 +-+universal
 ++++arm64
 + EOF
 +     fi
 +@@ -275,25 +275,11 @@ port install \
 +              libpng \
 +              jpeg \
 +              tiff \
 +-             boost \
 +-             eigen3 \
 +              gettext \
 +              libusb \
 +-             libgphoto2 \
 +-             jasper \
 +-             lcms2 \
 +-             expat \
 +              libxml2 \
 +              libxslt \
 +              libical \
 +-             lensfun \
 +-             bison \
 +-             py38-lxml \
 +-             x265 \
 +-             libde265 \
 +-             libheif \
 +-             aom \
 +-             ffmpeg \
 +              wget +ssl \
 +              qt5-qtbase \
 +              qt5-qtdeclarative \
 +@@ -305,22 +291,11 @@ port install \
 +              qt5-qttranslations \
 +              qt5-qtimageformats \
 +              qt5-qtnetworkauth \
 +-             qt5-sqlite-plugin \
 +-             qt5-mysql-plugin $MP_MARIADB_VARIANT
 ++             qt5-sqlite-plugin
 +-port deactivate boost
 ++#port deactivate boost
 +-if [[ $DK_QTWEBENGINE = 1 ]] ; then
 +-    port install qt5-qtwebengine
 +-else
 +-    port install qt5-qtwebkit
 +-fi
 +-port activate boost
 + # port broken since a while. check later
 + #             sane-backends \
 +@@ -360,18 +335,7 @@ cmake $ORIG_WD/../3rdparty \
 +        -DKA_VERSION=$DK_KA_VERSION \
 +        -DKP_VERSION=$DK_KP_VERSION \
 +        -DKDE_VERSION=$DK_KDE_VERSION \
 +-       -DENABLE_QTVERSION=$DK_QTVERSION \
 +-       -DENABLE_QTWEBENGINE=$DK_QTWEBENGINE \
 +-       -Wno-dev
 +-    cmake --build . --config RelWithDebInfo --target ext_qtwebkit    -- -j$CPU_CORES
 +-fi
 +-cmake --build . --config RelWithDebInfo --target ext_opencv      -- -j$CPU_CORES
 +-cmake --build . --config RelWithDebInfo --target ext_imagemagick -- -j$CPU_CORES
 +-cmake --build . --config RelWithDebInfo --target ext_libjxl      -- -j$CPU_CORES
 +-cmake --build . --config RelWithDebInfo --target ext_libavif     -- -j$CPU_CORES
 ++       -DENABLE_QTVERSION=$DK_QTVERSION
 +diff --git a/project/bundles/macports/02-build-extralibs.sh b/project/bundles/macports/02-build-extralibs.sh
 +index a94632c1a6..ca39301c7f 100755
 +--- a/project/bundles/macports/02-build-extralibs.sh
 ++++ b/project/bundles/macports/02-build-extralibs.sh
 +@@ -68,16 +68,15 @@ cmake $ORIG_WD/../3rdparty \
 +-       -Wno-dev
 + # core KF5 frameworks dependencies
 + cmake --build . --config RelWithDebInfo --target ext_extra-cmake-modules -- -j$CPU_CORES
 + cmake --build . --config RelWithDebInfo --target ext_kconfig             -- -j$CPU_CORES
 +-cmake --build . --config RelWithDebInfo --target ext_breeze-icons        -- -j$CPU_CORES
 ++#cmake --build . --config RelWithDebInfo --target ext_breeze-icons        -- -j$CPU_CORES
 + cmake --build . --config RelWithDebInfo --target ext_kcoreaddons         -- -j$CPU_CORES
 + cmake --build . --config RelWithDebInfo --target ext_kwindowsystem       -- -j$CPU_CORES
 + cmake --build . --config RelWithDebInfo --target ext_solid               -- -j$CPU_CORES
 +@@ -106,10 +105,10 @@ cmake --build . --config RelWithDebInfo --target ext_kimageformats       -- -j$C
 + #cmake --build . --config RelWithDebInfo --target ext_libksane            -- -j$CPU_CORES
 + # Calendar support
 +-cmake --build . --config RelWithDebInfo --target ext_kcalendarcore       -- -j$CPU_CORES
 ++#cmake --build . --config RelWithDebInfo --target ext_kcalendarcore       -- -j$CPU_CORES
 + # Breeze style support
 +-cmake --build . --config RelWithDebInfo --target ext_breeze              -- -j$CPU_CORES
 ++#cmake --build . --config RelWithDebInfo --target ext_breeze              -- -j$CPU_CORES
 +diff --git a/project/bundles/macports/config.sh b/project/bundles/macports/config.sh
 +index 37341eefb0..65c9e37442 100644
 +--- a/project/bundles/macports/config.sh
 ++++ b/project/bundles/macports/config.sh
 +@@ -16,7 +16,7 @@ BUILDING_DIR="`pwd`/temp.build"
 + # Target macOS architecture: "x86_64" for Intel 64 bits, or "arm64" for Apple Silicon 64 bits.
 +-ARCH_TARGET="x86_64"
 ++ARCH_TARGET="arm64"
 + if [[ $ARCH_TARGET = "x86_64" ]] ; then
 +@@ -50,7 +50,7 @@ if [[ $ARCH_TARGET = "x86_64" ]] ; then
 + elif [[ $ARCH_TARGET = "arm64" ]] ; then
 +     # Apple Silicon is supported since macOS BigSur
 +-    OSX_MIN_TARGET="11.0"
 ++    OSX_MIN_TARGET="12.3"
 + else
 +@@ -128,7 +128,7 @@ DK_VERSION=master
 + DK_DEBUG=0
 +-DK_QTWEBENGINE=1
 ++DK_QTWEBENGINE=0
 + # Sign bundles with GPG. Passphrase must be hosted in ~/.gnupg/dkorg-gpg-pwd.txt
 + DK_SIGN=0
 +Add in your .bash_profile or in zsh profile [[https://support.apple.com/en-ca/HT208050|see]]
 +PATH="/opt/digikam.org.arm64/libexec/qt5/bin:${PATH}"
 +PATH="/opt/digikam.org.arm64/bin:${PATH}"
 +export PATH=/opt/digikam.org.arm64/libexec:$PATH
 +export PATH=/opt/digikam.org.arm64/include:$PATH
 +Copy your libs KF5 *.pri  /opt/digikam.org.arm64/mkspecs/modules/  to /opt/digikam.org.arm64/libexec/qt5/mkspecs/modules/
 +Edit your libs KF5 *.pri files in /opt/digikam.org.arm64/libexec/qt5/mkspecs/modules/ like this:
 +QT.KCoreAddons.VERSION = 5.110.0
 +QT.KCoreAddons.MAJOR_VERSION = 5
 +QT.KCoreAddons.MINOR_VERSION = 110
 +QT.KCoreAddons.PATCH_VERSION = 0
 +QT.KCoreAddons.name = KF5CoreAddons
 +QT.KCoreAddons.module = KF5CoreAddons
 +QT.KCoreAddons.defines =
 +QT.KCoreAddons.includes =  $$PWD/../../include/KF5/KCoreAddons
 +QT.KCoreAddons.private_includes =
 +QT.KCoreAddons.libs = $$PWD/../../lib
 +QT.KCoreAddons.depends = core
 +QT.KCoreAddons.module_config =
 +To:
 +QT.KCoreAddons.includes =  /opt/digikam.org.arm64/include/KF5/KCoreAddons
 +QT.KCoreAddons.libs = /opt/digikam.org.arm64/lib
 ===== MacOS Macports environment (new 2023) ===== ===== MacOS Macports environment (new 2023) =====
Ligne 39: Ligne 258:
 </code> </code>
 +Note : On APPLE M1/2 chips replace in PATH  /opt/digikam.org.x86_64 by /opt/digikam.org.arm64 \\
 +but with Qt 5.15.8 environment can't compil like:
 +//Can't build QET with MacPorts and Digikam scripts, I have linking errors:
 +............building for macOS-arm64 but attempting to link with file config macOS-x86_64..... For KF5 libs...//
 +Get GIT sources
 +Build bundle:
 +We need to add lang1 in qet_git directory with [[https://download.qelectrotech.org/qet/Qt_lang/lang1.zip|these unzipped files]] \\
 +And create a MAC_OS_X directory in your home otherwise bundles builds was located in /build-aux/mac-osx/ folder.
 +bash qet_git/misc/MacQetDeploy.sh
 ===== MacOS Homebrew environment (old) ===== ===== MacOS Homebrew environment (old) =====
Ligne 112: Ligne 347:
 <code> <code>
-git clone git://git.tuxfamily.org/gitroot/qet/qet.git qet_git+git clone --recursive https://github.com/qelectrotech/qelectrotech-source-mirror.git
 </code> </code>
