doc:macosx [20/09/2019 11:42] – scorpio810 | doc:macosx [09/01/2024 16:01] (Version actuelle) – [Macports arm64 Apple silicon environments MAC Mini M2] scorpio810 | ||
+ | ===== Macports arm64 Apple silicon environments MAC Mini M2 ===== | ||
+ | git clone https:// | ||
+ | cd digikam/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | sed -i '' | ||
+ | diff --git a/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | cat << EOF >> " | ||
+ | -+universal | ||
+ | +++arm64 | ||
+ | EOF | ||
+ | fi | ||
+ | libpng \ | ||
+ | jpeg \ | ||
+ | tiff \ | ||
+ | - boost \ | ||
+ | gettext \ | ||
+ | libusb \ | ||
+ | - lcms2 \ | ||
+ | - expat \ | ||
+ | libxml2 \ | ||
+ | libxslt \ | ||
+ | libical \ | ||
+ | - bison \ | ||
+ | - x265 \ | ||
+ | - aom \ | ||
+ | wget +ssl \ | ||
+ | qt5-qtbase \ | ||
+ | qt5-qtdeclarative \ | ||
+ | qt5-qttranslations \ | ||
+ | qt5-qtimageformats \ | ||
+ | qt5-qtnetworkauth \ | ||
+ | -else | ||
+ | -fi | ||
+ | -port activate boost | ||
+ | -fi | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | # Calendar support | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -ARCH_TARGET=" | ||
+ | +ARCH_TARGET=" | ||
+ | - OSX_MIN_TARGET=" | ||
+ | + OSX_MIN_TARGET=" | ||
+ | else | ||
+ | -DK_QTWEBENGINE=1 | ||
+ | +DK_QTWEBENGINE=0 | ||
+ | PATH="/ | ||
+ | PATH="/ | ||
+ | export PATH=/ | ||
+ | QT.KCoreAddons.includes = $$PWD/ | ||
+ | QT.KCoreAddons.libs = $$PWD/ | ||
+ | To: | ||
+ | ===== MacOS Macports environment (new 2023) ===== | ||
+ | We use now Digikam scripts, for create Qt 5.15.X compile environment with qt5-sqlite-plugin (Sqilte3) for database project exporting.\\ | ||
+ | See: | ||
+ | https:// | ||
+ | https:// | ||
+ | We only use __01-build-macports.sh__ and __02-build-extralibs.sh script__ to build MacOS Macports environment for QET builds. | ||
+ | //You can comment some packages which are not useful for QElectroTech \\ | ||
+ | like qt5-qtwebengine, | ||
+ | bash ./ | ||
+ | //you can comment some packages which are not useful for QElectroTech, | ||
+ | but keep ext_kcoreaddons and ext_kwidgetsaddons!// | ||
+ | bash ./ | ||
+ | # Setting PATH for Qt5.15.x | ||
+ | PATH="/ | ||
+ | PATH="/ | ||
+ | Note : On APPLE M1/2 chips replace in PATH / | ||
+ | Get GIT sources | ||
+ | Build bundle: | ||
+ | bash qet_git/ | ||
+ | ===== MacOS Homebrew environment (old) ===== | ||
+ | * Note : we can't use Qt 5 sqlite3 plug-in without compile Qt 5 \\ | ||
+ | [[https:// | ||
- | command xcode-select --install | ||
- | brew tap kde-mac/ | + | |
- | brew install | + | brew install qt@5 |
+ | brew untap kde-mac/kde 2> /dev/null | ||
+ | brew tap kde-mac/ | ||
+ | "$(brew --repo | ||
brew install kde-mac/ | brew install kde-mac/ | ||
Ligne 20: | Ligne 300: | ||
cp / | cp / | ||
cp / | cp / | ||
- | cp / | + | |
+ | Edit KF5 .pri file $$PWD/.../ PATH like this | ||
+ | QT.KCoreAddons.MINOR_VERSION = 99 | ||
+ | to | ||
+ | QT.KCoreAddons.VERSION = 5.99.0 | ||
+ | Same things for qt_KWidgetsAddons.pri | ||
cat .bash_profile | cat .bash_profile | ||
- | # Setting PATH for Qt5.13.1 | + | # Setting PATH for Qt5.15.7 |
- | PATH="/ | + | PATH="/ |
export PATH=/ | export PATH=/ | ||
export PATH | export PATH | ||
Ligne 34: | Ligne 347: | ||
Ligne 45: | Ligne 358: | ||
cd qet_git/ | cd qet_git/ | ||
qmake -spec macx-clang | qmake -spec macx-clang | ||
- | make -j16 | + | make -j24 |
+ | ===== Old Documentation ===== | ||
Ligne 55: | Ligne 369: | ||
Testé sous El Capitan (10.11). | Testé sous El Capitan (10.11). | ||
- | ===== Préparation de l' | + | ==== Préparation de l' |
==== Compiler un programme C++ : XCode ==== | ==== Compiler un programme C++ : XCode ==== | ||
Pour disposer d'un compilateur C++ et de l' | Pour disposer d'un compilateur C++ et de l' |
