doc:macosx [09/11/2023 21:13] – [MacOS Macports environment (new 2023)] scorpio810 | doc:macosx [09/01/2024 16:00] – [Macports arm64 Apple silicon environments MAC Mini M2] scorpio810 | ||
- | ====== Homebrew | + | ===== Macports |
- | / | + | git clone https://invent.kde.org/ |
+ | cd digikam/project/bundles/macports/ | ||
- | brew install qt@5 | ||
- | brew untap kde-mac/kde 2> /dev/null | ||
- | brew tap kde-mac/kde https:// | ||
- | < | + | <code=diff>diff --git a/ |
- | brew install kde-mac/kde/kf5-kwidgetsaddons | + | index 41a75f247f..04307322bd 100755 |
- | brew install | + | --- a/project/bundles/ |
+ | +++ b/ | ||
+ | sed -i '' | ||
+ | diff --git a/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | cat << EOF >> " | ||
+ | -+universal | ||
+ | +++arm64 | ||
+ | EOF | ||
+ | fi | ||
+ | @@ -275,25 +275,11 @@ port install | ||
+ | libpng \ | ||
+ | jpeg \ | ||
+ | tiff \ | ||
+ | - boost \ | ||
+ | gettext \ | ||
+ | libusb \ | ||
+ | - lcms2 \ | ||
+ | - expat \ | ||
+ | libxml2 \ | ||
+ | libxslt \ | ||
+ | libical \ | ||
+ | - bison \ | ||
+ | - x265 \ | ||
+ | - aom \ | ||
+ | wget +ssl \ | ||
+ | qt5-qtbase \ | ||
+ | qt5-qtdeclarative \ | ||
+ | qt5-qttranslations \ | ||
+ | qt5-qtimageformats \ | ||
+ | qt5-qtnetworkauth \ | ||
+ | -else | ||
+ | -fi | ||
+ | -port activate boost | ||
+ | @@ -360,18 +335,7 @@ cmake $ORIG_WD/../3rdparty \ | ||
+ | -fi | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | # Calendar support | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -ARCH_TARGET=" | ||
+ | +ARCH_TARGET=" | ||
+ | - OSX_MIN_TARGET=" | ||
+ | + OSX_MIN_TARGET=" | ||
+ | -DK_QTWEBENGINE=1 | ||
+ | +DK_QTWEBENGINE=0 | ||
- | Copy your libs KF5 *.pri to your Qt brew install | + | Add in your .bash_profile or in zsh profile [[https:// |
- | like: | + | |
- | cp /opt/homebrew/ | + | PATH="/opt/digikam.org.arm64/libexec/qt5/bin: |
- | cp /opt/homebrew/ | + | PATH="/opt/digikam.org.arm64/bin: |
+ | export PATH=/opt/digikam.org.arm64/libexec: | ||
+ | export PATH=/opt/digikam.org.arm64/include: | ||
- | cat / | ||
- | QT.KCoreAddons.VERSION = 5.102.0 | + | Copy your libs KF5 *.pri / |
QT.KCoreAddons.MAJOR_VERSION = 5 | QT.KCoreAddons.MAJOR_VERSION = 5 | ||
- | QT.KCoreAddons.MINOR_VERSION = 102 | + | QT.KCoreAddons.MINOR_VERSION = 110 |
QT.KCoreAddons.PATCH_VERSION = 0 | QT.KCoreAddons.PATCH_VERSION = 0 | ||
QT.KCoreAddons.name = KF5CoreAddons | QT.KCoreAddons.name = KF5CoreAddons | ||
QT.KCoreAddons.module = KF5CoreAddons | QT.KCoreAddons.module = KF5CoreAddons | ||
QT.KCoreAddons.defines = | QT.KCoreAddons.defines = | ||
- | QT.KCoreAddons.includes = /opt/homebrew/ | + | QT.KCoreAddons.includes = /opt/digikam.org.arm64/ |
QT.KCoreAddons.private_includes = | QT.KCoreAddons.private_includes = | ||
- | QT.KCoreAddons.libs = /opt/homebrew/ | + | QT.KCoreAddons.libs = /opt/digikam.org.arm64/lib |
QT.KCoreAddons.depends = core | QT.KCoreAddons.depends = core | ||
QT.KCoreAddons.module_config = | QT.KCoreAddons.module_config = | ||
- | cat / | ||
- | QT.KWidgetsAddons.VERSION = 5.102.0 | ||
- | QT.KWidgetsAddons.MAJOR_VERSION = 5 | ||
- | QT.KWidgetsAddons.MINOR_VERSION = 102 | ||
- | QT.KWidgetsAddons.PATCH_VERSION = 0 | ||
- | QT.KWidgetsAddons.name = KF5WidgetsAddons | ||
- | QT.KWidgetsAddons.module = KF5WidgetsAddons | ||
- | QT.KWidgetsAddons.defines = | ||
- | QT.KWidgetsAddons.includes = / | ||
- | QT.KWidgetsAddons.private_includes = | ||
- | QT.KWidgetsAddons.libs = / | ||
- | QT.KWidgetsAddons.depends = widgets | ||
- | QT.KWidgetsAddons.module_config = | ||
- | < | + | To: |
- | export PATH="/ | + | |
- | export LDFLAGS="-L/opt/homebrew/opt/qt@5/lib" | + | |
- | export CPPFLAGS="-I/opt/homebrew/opt/ | + | QT.KCoreAddons.VERSION = 5.110.0 |
- | </ | + | QT.KCoreAddons.MAJOR_VERSION |
+ | QT.KCoreAddons.MINOR_VERSION | ||
+ | QT.KCoreAddons.includes = | ||
+ | QT.KCoreAddons.libs | ||
- | --- qelectrotech.pro | ||
- | +++ qelectrotech.pro | ||
- | @@ -58,7 +58,7 @@ DEFINES += QET_ALLOW_OVERRIDE_CTBTD_OPTION | ||
- | -DEFINES += QET_EXPORT_PROJECT_DB | ||
- | +#DEFINES += QET_EXPORT_PROJECT_DB | ||
- | # warn on *any* usage of deprecated APIs | ||
- | @@ -244,7 +244,7 @@ TARGET = qelectrotech | ||
- | # Ajustement des bibliotheques utilisees lors de l' | ||
- | -unix|win32: | ||
- | # Enable C++17 | ||
- | @@ -312,7 +312,7 @@ macx { | ||
- | # les chemins definis precedemment sont relatifs au dossier contenant le binaire executable | ||
- | - LIBS += / | ||
- | + #LIBS += / | ||
- | # Compilers-specific options | ||
===== MacOS Macports environment (new 2023) ===== | ===== MacOS Macports environment (new 2023) ===== | ||
Ligne 222: | Ligne 348: | ||
