doc:macosx [26/02/2023 19:54] – scorpio810 | doc:macosx [09/01/2024 16:00] – [Macports arm64 Apple silicon environments MAC Mini M2] scorpio810 | ||
- | ====== Hombrew | + | ===== Macports |
+ | git clone https:// | ||
+ | cd digikam/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | sed -i '' | ||
+ | diff --git a/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | cat << EOF >> " | ||
+ | -+universal | ||
+ | +++arm64 | ||
+ | EOF | ||
+ | fi | ||
+ | libpng \ | ||
+ | jpeg \ | ||
+ | tiff \ | ||
+ | - boost \ | ||
+ | gettext \ | ||
+ | libusb \ | ||
+ | - lcms2 \ | ||
+ | - expat \ | ||
+ | libxml2 \ | ||
+ | libxslt \ | ||
+ | libical \ | ||
+ | - bison \ | ||
+ | - x265 \ | ||
+ | - aom \ | ||
+ | wget +ssl \ | ||
+ | qt5-qtbase \ | ||
+ | qt5-qtdeclarative \ | ||
+ | qt5-qttranslations \ | ||
+ | qt5-qtimageformats \ | ||
+ | qt5-qtnetworkauth \ | ||
+ | -else | ||
+ | -fi | ||
+ | -port activate boost | ||
+ | -fi | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | # Calendar support | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -ARCH_TARGET=" | ||
+ | +ARCH_TARGET=" | ||
+ | - OSX_MIN_TARGET=" | ||
+ | + OSX_MIN_TARGET=" | ||
+ | else | ||
+ | -DK_QTWEBENGINE=1 | ||
+ | +DK_QTWEBENGINE=0 | ||
+ | PATH="/ | ||
+ | PATH="/ | ||
+ | export PATH=/ | ||
+ | To: | ||
===== MacOS Macports environment (new 2023) ===== | ===== MacOS Macports environment (new 2023) ===== | ||
Ligne 44: | Ligne 259: | ||
- | Note : On APPLE M1/2 chips replace in PATH / | + | Note : On APPLE M1/2 chips replace in PATH / |
Get GIT sources | Get GIT sources | ||
Build bundle: | Build bundle: | ||
- | We need to add lang1 in qet_git directory with [[https:// | + | We need to add lang1 in qet_git directory with [[https:// |
And create a MAC_OS_X directory in your home otherwise bundles builds was located in / | And create a MAC_OS_X directory in your home otherwise bundles builds was located in / | ||
Ligne 129: | Ligne 348: | ||
