doc:macosx [17/01/2023 18:04] – scorpio810 | doc:macosx [09/01/2024 16:00] – [Macports arm64 Apple silicon environments MAC Mini M2] scorpio810 | ||
- | ===== New 2023 MacOS Macports environment ===== | + | ===== Macports arm64 Apple silicon environments MAC Mini M2 ===== |
+ | git clone https:// | ||
+ | cd digikam/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | sed -i '' | ||
+ | diff --git a/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | cat << EOF >> " | ||
+ | -+universal | ||
+ | +++arm64 | ||
+ | EOF | ||
+ | fi | ||
+ | libpng \ | ||
+ | jpeg \ | ||
+ | tiff \ | ||
+ | - boost \ | ||
+ | gettext \ | ||
+ | libusb \ | ||
+ | - lcms2 \ | ||
+ | - expat \ | ||
+ | libxml2 \ | ||
+ | libxslt \ | ||
+ | libical \ | ||
+ | - bison \ | ||
+ | - x265 \ | ||
+ | - aom \ | ||
+ | wget +ssl \ | ||
+ | qt5-qtbase \ | ||
+ | qt5-qtdeclarative \ | ||
+ | qt5-qttranslations \ | ||
+ | qt5-qtimageformats \ | ||
+ | qt5-qtnetworkauth \ | ||
+ | -else | ||
+ | -fi | ||
+ | -port activate boost | ||
+ | -fi | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | # Calendar support | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -ARCH_TARGET=" | ||
+ | +ARCH_TARGET=" | ||
+ | - OSX_MIN_TARGET=" | ||
+ | + OSX_MIN_TARGET=" | ||
+ | -DK_QTWEBENGINE=1 | ||
+ | +DK_QTWEBENGINE=0 | ||
+ | PATH="/ | ||
+ | PATH="/ | ||
+ | export PATH=/ | ||
+ | To: | ||
+ | ===== MacOS Macports environment | ||
Ligne 12: | Ligne 232: | ||
https:// | https:// | ||
- | We only use 01-build-macports.sh and 02-build-extralibs.sh | + | We only use __01-build-macports.sh__ and __02-build-extralibs.sh |
git clone https:// | git clone https:// | ||
- | cd digikam/ | + | cd digikam/ |
- | You can comment some packages which are not useful for QElectroTech | + | //You can comment some packages which are not useful for QElectroTech |
+ | like qt5-qtwebengine, | ||
bash ./ | bash ./ | ||
- | If ok then | + | </ |
- | you can comment some packages which are not useful for QElectroTech | + | //you can comment some packages which are not useful for QElectroTech, \\ |
+ | but keep ext_kcoreaddons and ext_kwidgetsaddons!// | ||
- | Add in your .bash_profile | + | Add in your .bash_profile |
# Setting PATH for Qt5.15.x | # Setting PATH for Qt5.15.x | ||
PATH="/ | PATH="/ | ||
Ligne 35: | Ligne 259: | ||
+ | Note : On APPLE M1/2 chips replace in PATH / | ||
+ | Get GIT sources | ||
+ | Build bundle: | ||
+ | bash qet_git/ | ||
- | ===== Old | + | ===== MacOS Homebrew environment |
* Note : we can't use Qt 5 sqlite3 plug-in without compile Qt 5 \\ | * Note : we can't use Qt 5 sqlite3 plug-in without compile Qt 5 \\ | ||
Ligne 108: | Ligne 348: | ||
