doc:macosx [17/01/2023 14:52] – scorpio810 | doc:macosx [09/01/2024 16:01] (Version actuelle) – [Macports arm64 Apple silicon environments MAC Mini M2] scorpio810 | ||
- | ====== QElectroTech sous MacOSX | + | ===== QElectroTech sous MacOSX |
- | We use Digikam scripts | + | |
+ | ===== Macports arm64 Apple silicon environments MAC Mini M2 ===== | ||
+ | git clone https:// | ||
+ | cd digikam/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | sed -i '' | ||
+ | diff --git a/ | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | cat << EOF >> " | ||
+ | -+universal | ||
+ | +++arm64 | ||
+ | EOF | ||
+ | fi | ||
+ | libpng \ | ||
+ | jpeg \ | ||
+ | tiff \ | ||
+ | - boost \ | ||
+ | gettext \ | ||
+ | libusb \ | ||
+ | - lcms2 \ | ||
+ | - expat \ | ||
+ | libxml2 \ | ||
+ | libxslt \ | ||
+ | libical \ | ||
+ | - bison \ | ||
+ | - x265 \ | ||
+ | - aom \ | ||
+ | wget +ssl \ | ||
+ | qt5-qtbase \ | ||
+ | qt5-qtdeclarative \ | ||
+ | qt5-qttranslations \ | ||
+ | qt5-qtimageformats \ | ||
+ | qt5-qtnetworkauth \ | ||
+ | -else | ||
+ | -fi | ||
+ | -port activate boost | ||
+ | -fi | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | # Calendar support | ||
+ | --- a/ | ||
+ | +++ b/ | ||
+ | -ARCH_TARGET=" | ||
+ | +ARCH_TARGET=" | ||
+ | - OSX_MIN_TARGET=" | ||
+ | + OSX_MIN_TARGET=" | ||
+ | -DK_QTWEBENGINE=1 | ||
+ | +DK_QTWEBENGINE=0 | ||
+ | PATH="/ | ||
+ | PATH="/ | ||
+ | export PATH=/ | ||
+ | QT.KCoreAddons.includes = $$PWD/ | ||
+ | QT.KCoreAddons.libs = $$PWD/ | ||
+ | To: | ||
+ | ===== MacOS Macports environment (new 2023) ===== | ||
+ | We use now Digikam scripts, for create | ||
See: | See: | ||
- | https:// | + | https:// |
+ | https:// | ||
+ | We only use __01-build-macports.sh__ and __02-build-extralibs.sh script__ to build MacOS Macports environment for QET builds. | ||
+ | //You can comment some packages which are not useful for QElectroTech \\ | ||
+ | like qt5-qtwebengine, | ||
+ | bash ./ | ||
+ | //you can comment some packages which are not useful for QElectroTech, | ||
+ | but keep ext_kcoreaddons and ext_kwidgetsaddons!// | ||
+ | bash ./ | ||
+ | # Setting PATH for Qt5.15.x | ||
+ | PATH="/ | ||
+ | PATH="/ | ||
+ | Note : On APPLE M1/2 chips replace in PATH / | ||
+ | Get GIT sources | ||
+ | Build bundle: | ||
+ | bash qet_git/ | ||
+ | ===== MacOS Homebrew environment (old) ===== | ||
- | ====== Old toolchain build ====== | + | * Note : we can't use Qt 5 sqlite3 plug-in without compile Qt 5 \\ |
[[https:// | [[https:// | ||
Ligne 76: | Ligne 347: | ||
Ligne 91: | Ligne 362: | ||
+ | ===== Old Documentation ===== | ||
Ligne 97: | Ligne 369: | ||
Testé sous El Capitan (10.11). | Testé sous El Capitan (10.11). | ||
- | ===== Préparation de l' | + | ==== Préparation de l' |
==== Compiler un programme C++ : XCode ==== | ==== Compiler un programme C++ : XCode ==== | ||
Pour disposer d'un compilateur C++ et de l' | Pour disposer d'un compilateur C++ et de l' |
