<project version="0.1" >
    <diagram title="Schéma de test" cols="13" folio="1/1" height="320" colsize="50" author="Xavier" filename="mon_fichier.qet" date="20071202" >
        <defaultconductor type="simple" />
        <elements>
            <element x="80" y="60" type="common://monofilaire/contacts/commande/con_simple.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="0" orientation="0" />
                    <terminal x="0" y="17" id="1" orientation="2" />
                </terminals>
                <inputs>
                    <input x="2.75" y="3" text="C" />
                </inputs>
            </element>
            <element x="130" y="60" type="common://monofilaire/contacts/commande/con_simple.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="2" orientation="0" />
                    <terminal x="0" y="17" id="3" orientation="2" />
                </terminals>
                <inputs>
                    <input x="2.75" y="3" text="E" />
                </inputs>
            </element>
            <element x="130" y="170" type="common://monofilaire/contacts/commande/con_simple.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="4" orientation="0" />
                    <terminal x="0" y="17" id="5" orientation="2" />
                </terminals>
                <inputs>
                    <input x="2.75" y="3" text="F" />
                </inputs>
            </element>
            <element x="490" y="290" type="custom://unifilaire/Lampe.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-27" id="6" orientation="0" />
                </terminals>
                <inputs>
                    <input x="15" y="0" text="H1" />
                </inputs>
            </element>
            <element x="310" y="280" type="common://monofilaire/recepteurs/commun/pc.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="7" orientation="0" />
                </terminals>
                <inputs/>
            </element>
            <element x="220" y="60" type="common://monofilaire/contacts/securite/ddr.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="8" orientation="0" />
                    <terminal x="0" y="17" id="9" orientation="2" />
                </terminals>
                <inputs>
                    <input x="5" y="-3" text="Q1" />
                    <input x="9" y="14" text="30mA" />
                </inputs>
            </element>
            <element x="220" y="280" type="common://monofilaire/recepteurs/commun/lampe.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="10" orientation="0" />
                </terminals>
                <inputs>
                    <input x="18" y="0" text="H1" />
                </inputs>
            </element>
            <element x="220" y="170" type="common://monofilaire/contacts/commande/interrupteur.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="11" orientation="0" />
                    <terminal x="0" y="17" id="12" orientation="2" />
                </terminals>
                <inputs>
                    <input x="2.75" y="3" text="S4" />
                </inputs>
            </element>
            <element x="80" y="170" type="common://monofilaire/contacts/commande/con_simple.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="13" orientation="0" />
                    <terminal x="0" y="17" id="14" orientation="2" />
                </terminals>
                <inputs>
                    <input x="2.75" y="3" text="D" />
                </inputs>
            </element>
            <element x="30" y="170" type="common://monofilaire/contacts/commande/con_simple.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="15" orientation="0" />
                    <terminal x="0" y="17" id="16" orientation="2" />
                </terminals>
                <inputs>
                    <input x="2.75" y="3" text="B" />
                </inputs>
            </element>
            <element x="30" y="60" type="common://monofilaire/contacts/commande/con_simple.elmt" orientation="0" >
                <terminals>
                    <terminal x="0" y="-17" id="17" orientation="0" />
                    <terminal x="0" y="17" id="18" orientation="2" />
                </terminals>
                <inputs>
                    <input x="2.75" y="3" text="A" />
                </inputs>
            </element>
        </elements>
        <conductors>
            <conductor neutral="true" phase="2" terminal1="3" ground="true" terminal2="4" type="single" />
            <conductor neutral="true" phase="1" terminal1="12" ground="true" terminal2="10" type="single" />
            <conductor terminal1="15" terminal2="18" type="simple" />
            <conductor num="42" terminal1="1" terminal2="13" type="multi" />
            <conductor neutral="true" phase="1" terminal1="9" ground="true" terminal2="11" type="single" />
            <conductor terminal1="6" terminal2="7" type="simple" >
                <segment length="-13" orientation="vertical" />
                <segment length="-66" orientation="vertical" />
                <segment length="-60" orientation="horizontal" />
                <segment length="60" orientation="vertical" />
                <segment length="-60" orientation="vertical" />
                <segment length="69" orientation="vertical" />
                <segment length="10" orientation="vertical" />
            </conductor>
        </conductors>
    </diagram>
</project>
Imprimer/exporter
