0000090QElectroTechwebsitepublic2026-09-24 11:25
ReporterMorganol Assigned To
PrioritynormalSeverityblockReproducibilityalways
PlatformQt5.6.1, kf5.27.0, Plasma5.8.0, OSLinux 4.7.6, gcc 5.4.0, OS VersionMageia 6
Summary0000090: For elements and templates, use localised names regardless if QET interface is translated or not...
DescriptionI.e for swedish, try to prefer this line in .elmt :
 <name lang="sv">A swedish translation of element name</name>
Like the user interface, fall back to en if localised line is not found.
This way users can more effifiently create new elements in QET which look more professional locally
-and maybe later better have time to contribute ;)
TagsNo tags attached.
Activities
Morganol
2016-10-07 17:59
reporter   ~0000173
It already correctly support *creation* of user collection folders and elements:
It even self writes "sv" in Langugae fields for creation of both folders and elements.
For folders It also displays the "sv" names in Collections pane when no other language is defined.
But elements are shown using file names instead :(
Morganol
2016-10-12 11:08
reporter   ~0000179
What language used should be evaluated separately element by element - at least for User collection
This have to have some fallback logic, and preferrably settable by user as a priority list;
1) system (settable by user to override)
2) best fallback (en by default?) settable; In sweden some may want danish or norwegian
3) secondary fallback (fr by default)
... maybe more items in list
If none in list: use filename
ispyisail
2026-09-24 11:25
developer   ~0000884
This works now, even when QET's interface is not translated into your language. Element and folder names follow the system language: on a Swedish system QET shows the <name lang="sv"> entry, then falls back to English, then to the file name. GitHub #537 (merged 2026-07-11) added the step that makes a regional locale such as sv_SE find the "sv" names.
https://github.com/qelectrotech/qelectrotech-source-mirror/pull/537
It is in the current development builds and will be in the next release. The user-set priority list (for example Danish before English) was not added. If you still want that, a new report just for it will be easier to track.
Issue History
2016-10-07 16:13 Morganol New Issue
2016-10-07 17:59 Morganol Note Added: 0000173
2016-10-12 11:08 Morganol Note Added: 0000179
2021-02-15 00:49 user245 Severity feature => block
2026-09-24 11:25 ispyisail Note Added: 0000884
2026-09-24 11:25 ispyisail Status new => resolved
2026-09-24 11:25 ispyisail Resolution open => fixed
