0000090 | QElectroTech | website | public | 2016-10-07 16:13 | 2021-02-15 00:50 |
Reporter | Morganol | Assigned To | |||
Priority | normal | Severity | block | Reproducibility | always |
Platform | Qt5.6.1, kf5.27.0, Plasma5.8.0, | OS | Linux 4.7.6, gcc 5.4.0, | OS Version | Mageia 6 |
Summary | 0000090: For elements and templates, use localised names regardless if QET interface is translated or not... | ||||
Description | I.e for swedish, try to prefer this line in .elmt : <name lang="sv">A swedish translation of element name</name> Like the user interface, fall back to en if localised line is not found. This way users can more effifiently create new elements in QET which look more professional locally -and maybe later better have time to contribute ;) | ||||
It already correctly support *creation* of user collection folders and elements: It even self writes "sv" in Langugae fields for creation of both folders and elements. For folders It also displays the "sv" names in Collections pane when no other language is defined. But elements are shown using file names instead :( |
What language used should be evaluated separately element by element - at least for User collection This have to have some fallback logic, and preferrably settable by user as a priority list; 1) system (settable by user to override) 2) best fallback (en by default?) settable; In sweden some may want danish or norwegian 3) secondary fallback (fr by default) ... maybe more items in list If none in list: use filename |
2016-10-07 16:13 | Morganol | New Issue | |
2016-10-07 17:59 | Morganol | Note Added: 0000173 | |
2016-10-12 11:08 | Morganol | Note Added: 0000179 | |
2021-02-15 00:45 |
2021-02-15 00:49 |
Severity | feature => block |
2021-02-15 00:50 |
