0000078QElectroTechwebsitepublic2021-02-15 00:52
Reporterchampalumeau Assigned Toscorpio810_mantis
PrioritynormalSeveritymajorReproducibilityalways
Status closedResolutionfixed
Summary0000078: if i itry to insert components from QET zip sous categories3 QET se bloque
DescriptionWith Qelectrotech V05 QT5 on Mageia 6 (depots mageia)
I had downloaded here:https://qelectrotech.org/showcategory.php
the zipped Elements directories:
collection_officielle
moderation
all_comers
and unzipped in .qet / elements
The attempt to insert one of these items in qelectrotech, blocks all!
see description below.
Erasure of the directory .qet is not enough to restore, you must also reboot and I had to do it twice in order to work again with qelectrotech.
I started the experience again and the crash happened again.
So it seems to be a problem in qelectrotech!
Steps To Reproduce1.Start Mga6
2.Start QET ( from depots MGA ou From QET , its same problem)
3.open a new or existig document
4 I try to modify it ( select parts , insert components....)
QET launches successfully and displays everything normally.
If I open an existing file it is displayed correctly with the various tabs
but it is impossible to change or select nothing in the diagrams. It is also impossible to insert a component.
We can still correctly close the file and reopen it.
I tried to urpme this soft and reinstall it but the problème is still here.
I tried to launch from terminal :
=> [root@localhost lajoiejp]# qelectrotech
libpng warning: iCCP: known incorrect sRGB profile
libpng warning: iCCP: too many profiles
org.kde.knotifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
transaction began for "common"
transaction commited for "common"
transaction began for "custom"
transaction commited for "custom"
By this way qelectrotech launches and works properly.
But if we try to open a file to save the diagram or opening an existing file we have this error:
'Can not start the process impossible to engage with KLauncher. Not connected to D-Bus server '
TagsNo tags attached.
Activities
scorpio810_mantis
2016-06-08 19:22
administrator   ~0000146
moderation
all_comers
champalumeau
why you need to paste all elements collections in your home collection, is the same elements?
scorpio810_mantis
2016-06-08 19:26
administrator   ~0000147
1.Start Mga6
champalumeau
Problem in MGA packaging?
champalumeau
2016-06-09 16:37
reporter   ~0000148
it don't seems to be a Mageia packaging problem.the bug seems linked with elements in .qet ?
but sometimes its works correctly and sometimes it crashes ...
for the moment, I do not find exactly when the soft blocks.
I noticed the absence of the icons to open / close / minimize the window when qelectrotech come unresponsive.
scorpio810_mantis
2016-06-09 16:51
administrator   ~0000149
0.5 version need lot of RAM memory.
You could test latest nightly 0.51 devel in other distribution, like Debian, Ubuntu, Fedora?
At my work, I have to very many elements and run fine in my Debian, you are the first user requesting this problem.
champalumeau
2016-06-09 17:36
reporter   ~0000150
I was looking for more components and i see that some where in the zip file from QET.
I am on Mageia, i know that it was working right on mageia5
I am testing mageia6 and before qelectrotech was ok but now i see a bug .
please check at https://bugs.mageia.org/show_bug.cgi?id=18625 the bugzilla for mageia where i also post. The problem is more explained.
TKS
scorpio810_mantis
2016-06-09 18:01
administrator   ~0000151
j pierre LAJOIE 2016-06-05 19:11:18 CEST
I can not find the folder with .qet/ config file
in .qet I have :
Elements
titleblocs
elements-cache. sqlite
See in your ~/.config/QElectroTech/
champalumeau
2016-06-09 19:51
reporter   ~0000152
i don't have : ~/.config/QElectroTech/ the .conf in .qet ?????
i don'nt know where is this config file ?
scorpio810_mantis
2016-06-10 06:41
administrator   ~0000153
QElectroTech version 0.5 released EN
For GNU/Linux distributions:
$HOME/.config/QElectroTech/QElectroTech.conf
champalumeau
2016-06-10 10:14
reporter   ~0000154
this is copy from my last post in mageia bugzilla :
 Exact the most important problem (selection, insertion of elements, schematics changes impossible) is linked to Caudron. In fact I was under kde5, workspace appearance / Oxygen. I changed to kde5, workspace appearance / Mageia and there, oh miracle! qelectrotech operates again normally.
By cons I have found nothing to restore proper management of the opening, closing or reduction of the main window (missing icons)
champalumeau
2016-06-10 17:23
reporter   ~0000155
and the window gestion problem was simply due to the option "full screen " activated . Now everything is correct.
scorpio810_mantis
2016-06-10 22:52
administrator   ~0000156
Ok, thank you.
Issue History
2016-06-07 14:27 champalumeau New Issue
2016-06-08 19:22 scorpio810_mantis Note Added: 0000146
2016-06-08 19:26 scorpio810_mantis Note Added: 0000147
2016-06-09 16:37 champalumeau Note Added: 0000148
2016-06-09 16:51 scorpio810_mantis Note Added: 0000149
2016-06-09 17:36 champalumeau Note Added: 0000150
2016-06-09 18:01 scorpio810_mantis Note Added: 0000151
2016-06-09 19:51 champalumeau Note Added: 0000152
2016-06-10 06:41 scorpio810_mantis Note Added: 0000153
2016-06-10 06:42 scorpio810_mantis Note Edited: 0000153
2016-06-10 06:43 scorpio810_mantis Note Edited: 0000153
2016-06-10 10:14 champalumeau Note Added: 0000154
2016-06-10 17:23 champalumeau Note Added: 0000155
2016-06-10 22:52 scorpio810_mantis Note Added: 0000156
2016-06-10 22:52 scorpio810_mantis Status new => closed
2016-06-10 22:52 scorpio810_mantis Assigned To => scorpio810_mantis
2016-06-10 22:52 scorpio810_mantis Resolution open => fixed
2021-02-15 00:52 user245 Category Libraries of elements => website
