| 0000077 | QElectroTech | website | public | 2016-04-17 12:41 | 2021-02-15 00:53 |
| Reporter | OSSau2mation | Assigned To | scorpio810_mantis | ||
| Priority | low | Severity | minor | Reproducibility | always |
| Summary | 0000077: Missing translations (minor) | ||||
| Description | Ihave attached a pdf document showing some missing translation I have noticed running the latest SVN/trunk (4442) Hope it is clear which I'm talking about | ||||
| Attached Files | |||||
For Debian vs Windows is the same version? For Qt buttons see ../forum/viewtopic.php?pid=4039#p4039 I just find only qt_da.qm Danish translation in Qt sources. For translation string missing, i must update TS files.
Moving element into category where there already is an element with same name. fixed by commit 4444. <div></div> |
Same version for both Debian and Windows. I will take a look at the forum link. There is no master TS file I could use as template for qet_da.ts, then I could update myself? |
You can, but I prefer to do it for all translators. See ../wiki_new/doc/translation#comment_mettre_a_jour_les_fichiers_ts_a_partir_des_fichiers_sources sed -i 's/^TRANSLATIONS/#TRANSLATIONS/g' qelectrotech.pro /usr/lib/x86_64-linux-gnu/qt5/bin/lupdate -noobsolete qelectrotech.pro -ts lang/qet_{en,es,ru,pt,cs,pl,ca,de,ro,it,ar,sl,hr,el,nl,be,sl,zh,hu,pt_BR,da,sr}.ts sed -i 's/^#TRANSLATIONS/TRANSLATIONS/g' qelectrotech.pro |
No problem this time it is already fixed, I just need to be a little patient :-) |
Same version for both Debian and Windows : ok i found the problem, is in nsis scripts /packaging/windows/ <span style="font-family: monospace;"> QET64.nsi QET.nsi in </span><font face="monospace">SubSection "$(Energy)" </font> <font face="monospace">Not perfect, but fixed in 4448.</font> |
| 2016-04-17 12:41 | OSSau2mation | New Issue | |
| 2016-04-17 12:41 | OSSau2mation | File Added: QETminorbug.pdf | |
| 2016-04-17 13:10 | scorpio810_mantis | Note Added: 0000139 | |
| 2016-04-17 14:18 | scorpio810_mantis | Note Edited: 0000139 | |
| 2016-04-17 14:44 | OSSau2mation | Note Added: 0000140 | |
| 2016-04-17 15:09 | scorpio810_mantis | Note Added: 0000141 | |
| 2016-04-17 15:10 | scorpio810_mantis | Note Edited: 0000141 | |
| 2016-04-17 15:29 | OSSau2mation | Note Added: 0000142 | |
| 2016-04-17 15:34 | scorpio810_mantis | Note Added: 0000143 | |
| 2016-04-17 15:46 | scorpio810_mantis | Note Edited: 0000143 | |
| 2016-05-14 01:43 | scorpio810_mantis | Status | new => closed |
| 2016-05-14 01:43 | scorpio810_mantis | Assigned To | => scorpio810_mantis |
| 2016-05-14 01:43 | scorpio810_mantis | Resolution | open => fixed |
| 2016-05-14 01:47 | scorpio810_mantis | Status | closed => feedback |
| 2016-05-14 01:47 | scorpio810_mantis | Resolution | fixed => reopened |
| 2016-05-14 01:47 | scorpio810_mantis | Resolution | reopened => fixed |
| 2016-05-14 01:50 | scorpio810_mantis | Status | feedback => closed |
| 2016-10-22 16:20 | scorpio810_mantis | Status | closed => resolved |
| 2021-02-15 00:45 |
| 2021-02-15 00:53 |
Category | translation => website |
