| 0000072 | QElectroTech | website | public | 2015-10-23 13:36 | 2021-02-15 00:53 |
| Reporter | Albator | Assigned To | |||
| Platform | PC | OS | Windows | OS Version | 7 Pro french |
| Summary | 0000072: Crash when quit | ||||
| Description | I installed Installer_QElectroTech-0.5-b_x86_64-win64+4234-1.exe on Windows 7 Pro french version. I works fine but when I quit it, it crash. | ||||
| Steps To Reproduce | Start and then, quit QElectroTech. | ||||
| Attached Files | |||||
Same crash with Windows XP SP3 french version. |
If you start and then quit immediately then QElectroTech crash is true and yes we know this problem, you must leave the database to load before quit program. |
Fixed in rev 4533 |
r4776 on Linux exit with segmentation fault if closed while loading element collection. |
I meant r4786 |
Qt 5.7.1+dfsg-3 Dmitry Shachnev (8): Start a new changelog entry. Backport upstream change to fix accessibility-related crashes. Backport upstream fix to make QGtk3Dialog not crash on Wayland. Backport upstream change to fix crashes on exit in some applications. Close bug #850746 in the changelog. Revert "Backport upstream change to fix crashes on exit in some applications." Backport change to stop unloading plugins in QPluginLoader and QFactoryLoader. Release to unstable. |
| 2015-10-23 13:36 | Albator | New Issue | |
| 2015-10-23 13:36 | Albator | File Added: Capture.png | |
| 2015-10-23 13:49 | Albator | Note Added: 0000122 | |
| 2015-10-23 13:50 | Albator | Note Edited: 0000122 | |
| 2015-10-23 13:50 | Albator | File Added: Capture2.png | |
| 2015-10-25 21:46 | scorpio810_mantis | Note Added: 0000124 | |
| 2016-05-28 17:36 | scorpio810_mantis | Note Added: 0000145 | |
| 2016-05-28 17:36 | scorpio810_mantis | Resolution | open => fixed |
| 2016-05-28 17:36 | scorpio810_mantis | Fixed in Version | => SVN/trunk |
| 2016-05-28 17:36 | scorpio810_mantis | Status | new => closed |
| 2016-05-28 17:36 | scorpio810_mantis | Assigned To | => scorpio810_mantis |
| 2016-10-22 16:29 | scorpio810_mantis | Status | closed => confirmed |
| 2016-10-22 16:29 | scorpio810_mantis | Resolution | fixed => reopened |
| 2016-10-22 16:33 | scorpio810_mantis | Assigned To | scorpio810_mantis => |
| 2016-10-22 16:33 | scorpio810_mantis | Status | confirmed => acknowledged |
| 2016-10-22 16:33 | scorpio810_mantis | Resolution | reopened => open |
| 2016-11-23 18:51 | Morganol | Note Added: 0000209 | |
| 2016-11-23 18:52 | Morganol | Note Added: 0000210 | |
| 2017-01-12 00:52 | scorpio810_mantis | Status | acknowledged => resolved |
| 2017-01-12 00:52 | scorpio810_mantis | Resolution | open => fixed |
| 2017-01-12 00:52 | scorpio810_mantis | Note Added: 0000232 | |
| 2021-02-15 00:47 |
Product Version | => SVN/trunk |
| 2021-02-15 00:53 |
Category | other => website |
