| 0000345 | QElectroTech | Diagram Editor | public | 2026-10-02 07:21 | 2026-10-02 09:31 |
| Reporter | tomasB | Assigned To | |||
| Priority | normal | Severity | crash | Reproducibility | always |
| Platform | Windows | OS | Windows 11 | OS Version | 25H2 |
| Summary | 0000345: The application crashes when opening certain QElectroTech projects | ||||
| Description | Description I encountered repeated crashes when trying to open specific QElectroTech project files. The application closes instantly without showing any error dialog. Other projects open normally, so the issue appears to be related to the content or structure of certain project files. | ||||
| Steps To Reproduce | Steps to reproduce 1. Start QElectroTech - poratble version. 2. Go to File › Open. 3. Select an affected project (.qet file). 4. The application immediately crashes. Expected behavior The project should open normally without crashing. Actual behavior The application closes instantly after selecting the project file. No error message is shown. | ||||
| Additional Information | Additional information
| Attached Files | Crash report.txt (22,036 bytes)
===== crash_20260930-083302_2332.log ===== QET crash dump Version: 0.200.1-dev Git: 784a663c19681d6fe66870a5503daee88c271b0c OS: Windows 11 Version 25H2 (x86_64) Qt: 6.11.2 --- 2026-09-30 08:33:02.079 Warning: failed to load "qt_en" "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6/translations" ( D:/a/qelectrotech-source-mirror/qelectrotech-source-mirror/sources/qetapp.cpp 276 setLanguage ) (D:/a/qelectrotech-source-mirror/qelectrotech-source-mirror/sources/qetapp.cpp:274, void QETApp::setLanguage(const QString&)) 2026-09-30 08:33:03.496 Info: Start-up 2026-09-30 08:33:03.496 Info: debugging enabled: false 2026-09-30 08:33:03.496 Info: Qt library version: QVersionNumber(6.11.2) 2026-09-30 08:33:03.496 Info: Qt library path default prefix: "D:/QelectroTech/QEelectroTech-0.200.1/bin" 2026-09-30 08:33:03.496 Info: Qt library path documentation: "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6/doc" 2026-09-30 08:33:03.496 Info: Qt library path headers: "D:/QelectroTech/QEelectroTech-0.200.1/bin/include/qt6" 2026-09-30 08:33:03.496 Info: Qt library path libraries: "D:/QelectroTech/QEelectroTech-0.200.1/bin/lib" 2026-09-30 08:33:03.496 Info: Qt library path executables: "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6/bin" 2026-09-30 08:33:03.496 Info: Qt library path Qt binaries: "D:/QelectroTech/QEelectroTech-0.200.1/bin/bin" 2026-09-30 08:33:03.496 Info: Qt library path Qt plugins: "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6/plugins" 2026-09-30 08:33:03.496 Info: Qt library path installed QML extensions: "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6/qml" 2026-09-30 08:33:03.497 Info: Qt library path dependent Qt data: "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6" 2026-09-30 08:33:03.497 Info: Qt library path independent Qt data: "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6" 2026-09-30 08:33:03.497 Info: Qt library path translation: "D:/QelectroTech/QEelectroTech-0.200.1/bin/share/qt6/translations" 2026-09-30 08:33:03.497 Info: Qt library path examples: "D:/QelectroTech/QEelectroTech-0.200.1/bin/examples" 2026-09-30 08:33:03.497 Info: Qt library path Qt testcases: "D:/QelectroTech/QEelectroTech-0.200.1/bin/tests" 2026-09-30 08:33:03.497 Info: "GitRevision 784a663c19681d6fe66870a5503daee88c271b0c" 2026-09-30 08:33:03.497 Info: "QElectroTech V 0.200.1-dev" 2026-09-30 08:33:03.497 Info: "Compilation: GCC 16.2.0" 2026-09-30 08:33:03.497 Info: "Built with Qt 6.11.2 - x86_64 - Date : Sep 30 2026 : 04:23:33" 2026-09-30 08:33:03.497 Info: "Run with Qt 6.11.2 using 22 thread(s)" 2026-09-30 08:33:03.497 Info: "CPU : " 2026-09-30 08:33:03.497 Info: "RAM Total : 32 GB" 2026-09-30 08:33:03.497 Info: "RAM Available : 16 GB" 2026-09-30 08:33:03.497 Info: "GPU : " 2026-09-30 08:33:03.497 Info: "GPU RAM : RAM Total : B" 2026-09-30 08:33:03.497 Info: "OS : winnt - x86_64 - Version : Windows 11 Version 25H2 - Kernel : 10.0.26200" 2026-09-30 08:33:03.497 Info: 2026-09-30 08:33:03.497 Info: OS System language: "cs_CZ" 2026-09-30 08:33:03.497 Info: OS System Native Country Name: "�esko" 2026-09-30 08:33:03.497 Info: OS System Native Language Name: "�e�tina" 2026-09-30 08:33:03.497 Info: 2026-09-30 08:33:03.497 Info: System language defined in QET configuration: "en" 2026-09-30 08:33:03.497 Info: language Path: "D:/QelectroTech/QEelectroTech-0.200.1/lang/" 2026-09-30 08:33:03.497 Info: Loaded QET translation: "D:/QelectroTech/QEelectroTech-0.200.1/lang/qet_en.qm" 2026-09-30 08:33:03.497 Info: Loaded Qt translation: "D:/QelectroTech/QEelectroTech-0.200.1/lang/qt_en.qm" 2026-09-30 08:33:03.497 Info: Common Elements Dir: "D:/QelectroTech/QEelectroTech-0.200.1/elements/" 2026-09-30 08:33:03.497 Info: Common TitleBlock Templates Dir: "D:/QelectroTech/QEelectroTech-0.200.1/titleblocks/" 2026-09-30 08:33:03.497 Info: Custom Elements Dir: "D:/FIRMA/QelectroTech/elements/" 2026-09-30 08:33:03.497 Info: Custom TitleBlock Templates Dir: "D:/FIRMA/QelectroTech/titleblocks" 2026-09-30 08:33:03.497 Info: Company Elements Dir: "~/AppData/Roaming/QElectroTech/QElectroTech/elements-company/" 2026-09-30 08:33:03.497 Info: Company TitleBlock Templates Dir: "~/AppData/Roaming/QElectroTech/QElectroTech/titleblocks-company/" 2026-09-30 08:33:03.497 Info: 2026-09-30 08:33:03.497 Info: App-Config: see Registry "HKEY_CURRENT_USER/Software/QElectroTech/" 2026-09-30 08:33:03.497 Info: additional config-files: 2026-09-30 08:33:03.497 Info: App Config Location: "~/AppData/Local/QElectroTech/QElectroTech" 2026-09-30 08:33:03.497 Info: For data-files (user-/company-collections, titleblocks, etc.): 2026-09-30 08:33:03.497 Info: App Data Location: "~/AppData/Roaming/QElectroTech/QElectroTech" 2026-09-30 08:33:03.497 Info: Directory for project stalefiles: 2026-09-30 08:33:03.497 Info: Generic Data Location: "~/AppData/Local/stalefiles/QElectroTech/" 2026-09-30 08:33:03.497 Info: 2026-09-30 08:33:03.497 Info: Count the elements in your collections (Official-common-collection, company-collections, custom-collections): 2026-09-30 08:33:03.541 Info: Common Elements count: 8838 Elements 2026-09-30 08:33:03.542 Info: Custom Elements count: 55 Elements 2026-09-30 08:33:03.542 Info: Company Elements count: 1 Elements 2026-09-30 08:33:03.542 Info: 2026-09-30 08:33:03.542 Info: *** Qt screens *** 2026-09-30 08:33:03.542 Info: "( 1 : 1920 x 1200 )" 2026-09-30 08:33:03.542 Info: "( 2 : 3440 x 1440 )" 2026-09-30 08:33:03.542 Info: 2026-09-30 08:33:03.543 Info: DISK : C:/ 2026-09-30 08:33:03.543 Info: FileSystemType: "NTFS" 2026-09-30 08:33:03.543 Info: SizeTotal: 497 GB 2026-09-30 08:33:03.543 Info: AvailableSize: 178 GB 2026-09-30 08:33:03.543 Info: DISK : D:/ 2026-09-30 08:33:03.543 Info: FileSystemType: "NTFS" 2026-09-30 08:33:03.543 Info: SizeTotal: 524 GB 2026-09-30 08:33:03.543 Info: AvailableSize: 267 GB 2026-09-30 08:33:03.543 Info: DISK USED: D:/ 2026-09-30 08:33:03.543 Info: FileSystemType: "NTFS" 2026-09-30 08:33:03.543 Info: SizeTotal: 524 GB 2026-09-30 08:33:03.543 Info: AvailableSize: 267 GB 2026-09-30 08:33:03.543 Info: Count All Elements in collections = 8894 Elements 2026-09-30 08:33:03.768 Info: Elements collection reload 2026-09-30 08:33:04.121 Info: Elements collection finished to be loaded in 0.352 seconds 2026-09-30 08:33:06.144 Warning: EventLoopWatchdog: main thread stalled for 499 ms (expected a tick every 50 ms) (D:/a/qelectrotech-source-mirror/qelectrotech-source-mirror/sources/logging/eventloopwatchdog.cpp:54, void EventLoopWatchdog::tick()) 2026-09-30 08:33:10.939 Info: SQLite version: "3.53.4" 2026-09-30 08:33:11.548 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.550 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.550 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.552 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.552 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.553 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.553 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.556 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.556 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.557 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.558 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.558 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.569 Warning: EventLoopWatchdog: main thread stalled for 581 ms (expected a tick every 50 ms) (D:/a/qelectrotech-source-mirror/qelectrotech-source-mirror/sources/logging/eventloopwatchdog.cpp:54, void EventLoopWatchdog::tick()) 2026-09-30 08:33:11.665 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.666 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.666 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.667 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.667 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.855 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.856 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.857 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.857 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.857 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.858 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.858 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.859 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.859 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.859 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.860 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.860 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.860 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.861 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.861 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.861 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.862 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.862 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.863 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.863 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.863 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.864 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.864 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.864 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.865 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.865 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.865 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.866 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.866 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.867 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.867 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.867 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.868 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.868 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.868 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.869 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.869 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.870 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.870 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.871 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.871 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.872 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.872 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.873 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.874 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.881 Warning: EventLoopWatchdog: main thread stalled for 207 ms (expected a tick every 50 ms) (D:/a/qelectrotech-source-mirror/qelectrotech-source-mirror/sources/logging/eventloopwatchdog.cpp:54, void EventLoopWatchdog::tick()) 2026-09-30 08:33:11.941 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.942 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.943 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.943 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.944 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.944 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.944 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.945 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.945 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.945 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.946 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.946 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.946 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.947 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.947 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.947 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.948 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.948 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.949 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.950 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.951 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.951 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.951 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.952 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.952 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.952 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.953 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.953 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.953 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.954 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.954 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.954 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.955 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.955 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.955 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.956 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:11.957 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.063 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.063 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.064 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.064 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.064 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.065 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.065 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.066 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.066 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.066 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.067 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.067 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.068 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.069 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.070 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.070 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.070 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.071 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.071 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.071 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.072 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.072 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.072 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.073 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.080 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.080 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.080 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.081 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.081 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.117 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) 2026-09-30 08:33:12.119 Warning: QFont::setWeight: Weight must be between 1 and 1000, attempted to set 0 (:0, ) | ||||
Thanks for attaching the project and the log, they made this quick to find. The crash comes from a contact that is not linked to a coil and has a text using %{label} (your project has one, on folio 3). It was introduced on 21 September. The fix is in review: https://github.com/qelectrotech/qelectrotech-source-mirror/pull/1234 Once it is merged, the next nightly build opens your project. |
Fixed by GitHub #1234, merged on 2026-10-02: https://github.com/qelectrotech/qelectrotech-source-mirror/pull/1234 The fix will be in the next release. If you still see the problem in a build that includes it, add a note here and we will reopen this. |
| 2026-10-02 07:21 | tomasB | New Issue | |
| 2026-10-02 07:21 | tomasB | File Added: Schematic Single RL load 500W QET.zip | |
| 2026-10-02 07:21 | tomasB | File Added: Crash report.txt | |
| 2026-10-02 07:53 | ispyisail | Note Added: 0000929 | |
| 2026-10-02 09:31 | ispyisail | Note Added: 0000933 | |
| 2026-10-02 09:31 | ispyisail | Status | new => resolved |
| 2026-10-02 09:31 | ispyisail | Resolution | open => fixed |
