0000343QElectroTechotherpublic2026-10-01 05:12
ReporterFatalJamon Assigned To
PrioritynormalSeveritymajorReproducibilityalways
Summary0000343: 0.100 : file contents is not consistently saved the same way for the same visual
DescriptionI have this file at work using custom elements.
I created an extract for reproducibility attached here : https://github.com/ThomasPrioul/test-qet-export-diff
Whenever I close/open and save the file, the whole file is mixed up :
- attributes order
- elements order
So it's very hard to track diffs in git, it creates huge commits for nothing.
I can't reproduce the behavior on an empty new file where diffs seems much simpler.
Steps To ReproduceClone the attached git repo, open in 0.100 and save. the file contents change completely, despite having moved nothing on the diagram.
Tagsgit, qet, save, vsc
Activities
FatalJamon
2026-09-25 10:24
reporter   ~0000900
Btw this is for version 0.100.0 but I could not submit the form if I selected that.
scorpio810_mantis
2026-09-25 10:28
administrator   ~0000901
Fixed on 0.200.1 dev with Qt6 framework, why use old 0.100.0 version, you lost a big lot of new great features.
FatalJamon
2026-09-25 10:50
reporter   ~0000903
Sadly no, I just checked and the exact same problem still happens with our file.
You don't even need to change anything in the diagram, just open/save/close. and do it again. the file will be different.
I checked with my attached file in the issue.
In 0.200 from 5 hours ago, I opened the file and saved it (no modifications).
If I close/open/save, this file doesn't have the problem of modified content.
BUT, if I move one element in the file, all the <input> section items have changed position in the list.
In vscode diff visualization, it can detect that the items were effectively moved (see attached picture).
I updated the git repo to show this problem.
ispyisail
2026-09-25 11:21
developer   ~0000905
Thanks for the test repository, it made this easy to reproduce.
You're right that it still happens in 0.200. Opening and saving is stable, but after any edit QElectroTech writes the diagram's texts, shapes, images and tables in an order that changes from run to run. Your "moved one relay down 10px" commit shows exactly that.
A fix is proposed here: https://github.com/qelectrotech/qelectrotech-source-mirror/pull/1030
With it, moving that relay changes only the relay's own line in the file. The first save with the fix may reorder those sections once; after that they stay put.
Once a build with this change is available, could you try it on your real work file and say whether the diffs stay small?
FatalJamon
2026-09-25 11:25
reporter   ~0000906
For sure, I subscribed to the PR to know when it will be merged.
I'll let you know
FatalJamon
2026-09-29 08:53
reporter   ~0000914
It is fixed, now moving an element only changes a few lines in the whole doc. Thank you very much.
ispyisail
2026-10-01 05:12
developer   ~0000918
Thanks for confirming. Fixed by https://github.com/qelectrotech/qelectrotech-source-mirror/pull/1030, merged on 25 September, so it is in current development builds. Closing.
Issue History
2026-09-25 10:24 FatalJamon New Issue
2026-09-25 10:24 FatalJamon Tag Attached: git
2026-09-25 10:24 FatalJamon Tag Attached: qet
2026-09-25 10:24 FatalJamon Tag Attached: save
2026-09-25 10:24 FatalJamon Tag Attached: vsc
2026-09-25 10:24 FatalJamon Note Added: 0000900
2026-09-25 10:28 scorpio810_mantis Note Added: 0000901
2026-09-25 10:28 scorpio810_mantis Note Edited: 0000901
2026-09-25 10:50 FatalJamon Note Added: 0000903
2026-09-25 10:50 FatalJamon File Added: image.png
2026-09-25 11:21 ispyisail Note Added: 0000905
2026-09-25 11:25 FatalJamon Note Added: 0000906
2026-09-29 08:53 FatalJamon Note Added: 0000914
2026-10-01 05:12 ispyisail Note Added: 0000918
2026-10-01 05:12 ispyisail Status new => resolved
2026-10-01 05:12 ispyisail Resolution open => fixed
