| 0000339 | QElectroTech | Element Editor | public | 2026-08-13 16:43 | 2026-09-24 10:13 |
| Reporter | Alf | Assigned To | |||
| Priority | normal | Severity | feature | Reproducibility | always |
| OS | Windows 11 | OS Version | Version 2009 | ||
| Summary | 0000339: The interface to set the maximum number of slaves is not working | ||||
| Description | There is a problem when viewing a master’s settings in the element editor. After adding several slave elements on propieties, clicking OK and saving the element, when you reopen the element’s propieties, the list of slave elements only retains the first slave element. QElectroTech V 0.100.1-dev Compilation : GCC 16.2.0 Built with Qt 5.15.19 - x86_64 - Date : Aug 13 2026 : 09:48:17 Git Revision : 2186d2733fd19c2d86172389c9e48e45d54fe332 Run with Qt 5.15.19 using 16 thread(s) CPU : RAM Total : 24 GB RAM Available : 11 GB GPU : GPU RAM : RAM Total : B OS : winnt - x86_64 - Version : Windows 11 Version 2009 - Kernel : 10.0.26200 *** Qt screens *** ( 1 : 1920 x 1080 ) ( 2 : 1920 x 1080 ) | ||||
| Tags | element | ||||
https://github.com/qelectrotech/qelectrotech-source-mirror/pull/748 |
https://github.com/qelectrotech/qelectrotech-source-mirror/actions/runs/31795422428 |
Thanks for the report. This was fixed the day after you reported it, by Kellermorph's change (https://github.com/qelectrotech/qelectrotech-source-mirror/pull/748), and it is in the current development builds. Your build (2186d273, 13 August) was made just before the fix went in. One thing to check: if you reopened and saved an element with that build, it was saved with only the first slave group. Those elements need their groups entered again. Could you try a current development build and confirm it now keeps all the groups? If it does, I'll close this. |
| 2026-08-13 16:43 | Alf | New Issue | |
| 2026-08-13 16:43 | Alf | Tag Attached: element | |
| 2026-08-13 16:45 | Alf | OS | => Windows 11 |
| 2026-08-13 16:45 | Alf | OS Version | => Version 2009 |
| 2026-08-13 16:45 | Alf | Note Added: 0000858 | |
| 2026-08-13 16:45 | Alf | File Added: Captura de pantalla 2026-08-13 162927.jpg | |
| 2026-08-14 13:14 | scorpio810_mantis | Note Added: 0000859 | |
| 2026-08-14 13:15 | scorpio810_mantis | Note Added: 0000860 | |
| 2026-09-24 10:13 | ispyisail | Note Added: 0000866 |
