| 0000337 | QElectroTech | other | public | 2026-01-26 08:16 | 2026-05-13 17:34 |
| Reporter | ntd | Assigned To | |||
| Platform | Linux x64 | OS | ArchLinux | OS Version | rolling |
| Product Version | 0.100 | ||||
| Summary | 0000337: System provided pugixml not usable | ||||
| Description | I see a CMake option in `cmake/fetch_pugixml.cmake` to select if building pugixml or using the system provided one: option(BUILD_PUGIXML "Build pugixml library, use system one otherwise" YES) The problem is the source code only works with the former:
Either the `BUILD_PUGIXML` option is misleading or the code must be refactored to use `-I` compiler flags and `#include <pugixml.hpp>`. | ||||
| 2026-01-26 08:16 | ntd | New Issue | |
| 2026-05-13 17:34 | scorpio810_mantis | Note Added: 0000842 |
