0000328 | QElectroTech | Diagram Editor | public | 2025-06-16 14:23 | 2025-06-22 12:56 |
Reporter | liborprilesky | Assigned To | plc-user | ||
Status | closed | Resolution | fixed | ||
Platform | Windows | OS | Windows 11 Pro | OS Version | 26100.4351 |
Product Version | 0.100 | ||||
Fixed in Version | 0.100 | ||||
Summary | 0000328: Overlapping text on contact | ||||
Description | When I add a circuit breaker and I want to add an auxiliary contact to it, after I assign the contact to the breaker, the label of the auxiliary contact overlaps with the other text. | ||||
Steps To Reproduce | Add circuit beraker to the schema. Add NC contact. Assign the NC contact to the breaker. | ||||
Attached Files | |||||
Please search the QElectroTech-Forum for that topic! Use the keyword "overlap"! You'll find some threads how to solve this. |
It's not a bug ... just change setting: Menu --> Settings --> Configure QElectroTech --> New Project --> Tab "Cross References" --> Set Positioning by Master-/Slave-Type |
2025-06-16 14:23 | liborprilesky | New Issue | |
2025-06-16 14:23 | liborprilesky | File Added: Snímek obrazovky 2025-06-16 142148.png | |
2025-06-17 18:23 | plc-user | Note Added: 0000810 | |
2025-06-22 12:56 | plc-user | Assigned To | => plc-user |
2025-06-22 12:56 | plc-user | Status | new => closed |
2025-06-22 12:56 | plc-user | Resolution | open => fixed |
2025-06-22 12:56 | plc-user | Fixed in Version | => 0.100 |
2025-06-22 12:56 | plc-user | Note Added: 0000811 |
