0000324QElectroTechDiagram Editorpublic2025-10-20 23:33
ReporterLeonardo da Silva Assigned Toblack_sun
PriorityhighSeveritymajorReproducibilityalways
OSwinnt - x86_64OS VersionWindows 11
Summary0000324: Crash on "Add text"
DescriptionWhen copying a label with Ctrl + C, then editing its text properties, and after that trying to create a new label in the selection properties, QElectroTech crashes immediately.
Steps To ReproduceSelect an existing label on the diagram.
Press Ctrl + C to copy the text of label.
Open the label's properties and click inside the text field to edit the text.
While the text field is still focused, click on "Add Text" inside the selection properties.
The program crashes without any error message.
TagsNo tags attached.
another bug.mp4 (2,003,147 bytes)
Activities
plc-user
2025-05-30 08:28
developer   ~0000800
Crashes with segmentation fault when text of element is selected.
Does not crash, when only element is selected.
plc-user
2025-05-30 09:49
developer   ~0000802
I think I have found the location in the source code that leads to the crash when adding new text-item.
If you can compile QET yourself:
It's on github for next 0.100-dev - release.
Available as binaries since 30.05.2025 in version 0.100-dev.
black_sun
2025-10-20 23:33
developer   ~0000823
Fixed in commit 1b671990ee8435616725afdffba438fdfcd18069
Closed in commit 3cf90958997daccf7882cb5f921a1de915e932ee
Issue History
2025-05-27 15:27 Leonardo da Silva New Issue
2025-05-27 15:27 Leonardo da Silva File Added: another bug.mp4
2025-05-30 08:28 plc-user Note Added: 0000800
2025-05-30 09:49 plc-user Note Added: 0000802
2025-06-22 13:06 plc-user Note Edited: 0000802
2025-10-20 23:33 black_sun Assigned To => black_sun
2025-10-20 23:33 black_sun Status new => resolved
2025-10-20 23:33 black_sun Resolution open => fixed
2025-10-20 23:33 black_sun Note Added: 0000823
